Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
How much HP gain?
Old Aug 4, 2009 | 08:36 AM
zx14's Avatar
zx14
Default How much HP gain?
1999 vert, I have shorty header, Borla single muffler exhaust, and am about to put on my new LS6 intake and LS6 heads.
any guesses?
." I should do a cam too since its opened up, but worry about calif. smog test."
Old Aug 4, 2009 | 09:35 AM
Blu's Avatar
Blu
The LS6 intake/TB and 243 heads should net you 25-30rwhp possibly more.
Old Aug 4, 2009 | 10:26 AM
mitchell c's Avatar
mitchell c
I would definatly consider a more aggressive cam while the engine is apart. A cam with a 224 duration with a 114 or 115 LSA should pass the sniffer. You could also call Comp Cam and get their recommendation on what cam to use.
Old Aug 4, 2009 | 10:45 AM
zx14's Avatar
zx14
LS6 TB bigger than LS1?
Old Aug 4, 2009 | 11:12 AM
nickolbag's Avatar
nickolbag
Pretty sure the LS1/6 TB are exactly the same.
Old Aug 4, 2009 | 01:31 PM
zx14's Avatar
zx14
I thought so too
Old Aug 9, 2009 | 02:35 AM
MYLS6's Avatar
MYLS6
Throttle body size - same
Plenum volume - larger
runner volume - same
runner length - same
this is what I found for intakes
_______________ls1_____ls6
Plenum volume - 5.06L--5.19L
runner volume --.536L--.541L
runner length ---262mm-262mm
Im curious on the shorty headers, was that because of emmissions?
Old Aug 9, 2009 | 09:22 AM
simpleman68's Avatar
simpleman68
I've got my H/C set for sale in the C5 Parts section if you're interested.
http://forums.corvetteforum.com/c5-p...-for-sale.html
Scott
Old Aug 10, 2009 | 07:08 PM
zx14's Avatar
zx14
[QUOTE=MYLS6;1571073223]Throttle body size - same
yessis, the smog cops will get you with long tubes
Old Aug 11, 2009 | 03:37 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
I gained 20 rwhp with the 243's heads and 10 rwhp with the LS6 intake.
Old Aug 11, 2009 | 03:39 PM
1998whitecoupe-a4
Also I would have those heads ported if you could though.
Wish I did
To How much HP gain?
