Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
New Personal Best!!!
Old Aug 22, 2009 | 01:28 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Default New Personal Best!!! (Video added!!!)
Went out to the track again last night (Friday) and made a few passes. Here is my first pass:
7:33 PM
Reaction: .9135 (not focusing on the tree obvisously)
60ft: 1.6665
330ft: 4.8017
1/8 ET: 7.3800
1/8 MPH: 96.38
1/4 ET: 11.3759
1/4 MPH: 124.97
That pass felt great. I knew it was better than a 11.49 (last best). I was really excited.
Second pass. 8:32 pm
Reaction: .4127 (again...not focusing on the tree obvisously)
60ft: 1.6671
330ft: 4.8040
1/8 ET: 7.3834
1/8 MPH: 96.98
1/4 ET: 11.3731
1/4 MPH: 125.07
I had two other passes that are close to these numbers but not really worth posting because on one I hit third gear and the tires brok loose and I let out for a second and then got back into it.
Anyhoo... the Density Altitude was: 2778 feet and the Relative Density: 92.12 % so I believe the car still has a LOT in it and im so damn excited about the cold weather getting here in Nov-Dec!
Tell me what you guys think!!!
Here is the video. Here that bog at that launch!!! HAHAH 10's on motor soon!!!
http://www.youtube.com/watch?v=fimSKCPu0Qw
Old Aug 22, 2009 | 02:03 PM
pit-man's Avatar
pit-man
I think you have close to a ten second car there if you can get the sixty foot a little lower and wait on cold air !!! Nice going !
Pitt
Old Aug 22, 2009 | 02:31 PM
JDaniel's Avatar
JDaniel
Pitt
Thanks, man! Everytime I go out now I focus more and more on my launch and shifting. I actually shifted a little earlier in the RPMs like you guys suggested and it paid off by over a .10th of a second. My buddies are wanting me to go ahead and spray it into the 10's but I refuse. I want it to run 10's on motor and then spray it.
Old Aug 22, 2009 | 02:32 PM
Kurtomac's Avatar
Kurtomac
nice going...what kind of launch were you doin this time out
Old Aug 22, 2009 | 02:46 PM
sixspdvet's Avatar
sixspdvet
Nice numbers, getting close to that magic number..
Ernie
Old Aug 22, 2009 | 04:17 PM
JDaniel's Avatar
JDaniel
Still launching about 4500-5000. It comes out of the hole and all I can do is hang on. It felt great. Im still working the 60fts down so I can pull a 1.5?.
Old Aug 22, 2009 | 04:18 PM
JDaniel's Avatar
JDaniel
Ernie
Thanks, man! Im getting there. Im hoping the magic numbers will appear this winter.
Old Aug 22, 2009 | 04:27 PM
JDaniel's Avatar
JDaniel
Have you guys tried to throw a bag of ice on the intake inbetween runs to lower the IATs? I used to do that on my KB Cobra and it helped a ton. Just wondering if the LS guys do it also and have any luck with it?
Old Aug 22, 2009 | 05:28 PM
LSX4LIFE's Avatar
LSX4LIFE
what a pass, great numbers. what tires r you running if i can ask
Old Aug 22, 2009 | 06:46 PM
LS1LT1's Avatar
LS1LT1
Very impressive results, especially in that air.
Old Aug 22, 2009 | 11:29 PM
sixspdvet's Avatar
sixspdvet
I use to use Ice packs on mine, not sure if it made any difference ...I normaly use fans to cool the car down, and tranny...
My goal, was to get the tranny down to 140, and the oil down to 150, by the time you do your burnout and stage the temps are back up.
Cooler temps will bring some good numbers, just try and let her cool down between runs...
Ernie
Old Aug 22, 2009 | 11:43 PM
evo2ls1's Avatar
evo2ls1
great times , what H/C/I r u running if you dont mind me asking and also you have the mph to run 10's N/A i recently installed 4.10's and was worried about running out of gear what rpm's are you running through the traps at?
Old Aug 23, 2009 | 09:10 AM
JDaniel's Avatar
JDaniel
Thanks everyone! I get better with every trip so im hoping for 10's by the end of this year. If not... that will be my new years resolution! LOL
Im running 26X11.5 ET streets on 8" FireBird ABS wheels in the rear and Bias ply M&H Front runners on the front mounte to GTO spares using a 2" spacer.
My RPMs are about 6300-6500 when im crossing the line in fouth gear. It kinda worries me because im not going to have enough gear with the Nitrous when I decide to run it. I may have to move to a 28" tire. Here is my mod list:
Cartek Stage 4X heads. Includes, full porting heads intake, exhaust, and combustion
chamber, Manley sever duty stainless valves, 2.02 intake, 1.57 exhasut, seals, Manley dual springs, spring seats, seals, titanium retainers, milled .030, cleaned and assembled.
Custom grind Cartek Stage 2X Cam computer verified.
228-232 582-598 116LSA
Cromoly hardened push rods.
Cometic heavy duty head gaskets.
ASP under drive pulley with belts.
Roll master dual roller timing chain.
Z06 ported oil pump setup for the roll master.
FAST 3 piece intake manifold ported to 4X with a 90MM throttle opening.
Ported LS2 throttle body.
ECU Reprogram 97-2004 LS1 full dyno tune.
Notch piston for clearance.
Complete NX system installed includes, NX wet kit with 10# bottle, purge, MSD digital RPM window switch, timing retard module, custom switch panel with micro switches and LED lights, all wires, Bosch relays, and labor to install. Also includes, blow down tube, full throttle switch, Kenny Bell Boostapump, and NGK TR6 spark plugs.
Nano kit.
4.10 gears.
C5 passenger and driver side 300M output shaft with side gear.
C5 line lock kit includes pre-bent line with braided flex hose, inline line lock solenoid, and switch installed.
Vararam intake
Vararam Power duct
GM Racing spark plug wires
160* thermostat
New Coolant crossover
American Racing Headers (1 7/8 primaries 3" collector)
American Racing 3" X pipe
Borla Stinger 2.5" catback
Built tranny by Lethal Performance
Hurst short throw shifter
Spec III Clutch and Billet aluminum flywheel
Brand new Slave cylinder
Upgraded Tick Performance Master cylinder
Old Aug 23, 2009 | 03:49 PM
evo2ls1's Avatar
evo2ls1
great mod list and awesome times considering it is not a huge cam, well i will be staying N/A so i should be ok, your car on the jug is gonna be crazy fast, 28'' tire or re gear to 3.90's. Be sure to post your other result when you hit the magic 10 slip!
Old Aug 23, 2009 | 05:27 PM
sixspdvet's Avatar
sixspdvet
JD, You might consider putting tr55's in right now. The Tr6's are for Nos, so i'm thinking you could pickup some HP by changing...
Worth a try...
Ernie
Old Aug 23, 2009 | 05:51 PM
JDaniel's Avatar
JDaniel
I will give it a try and see what happens. I will just have to put a tag on my tank that reads "DONT FORGET TO PUT TR6's BACK IN BEFORE U SPRAY!!!" LOL Thanks, man.
Old Aug 24, 2009 | 01:13 AM
LS1LT1's Avatar
LS1LT1
Worth a try...
To New Personal Best!!!
Old Aug 24, 2009 | 05:02 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Very nice times!!!
Congrats!
Old Aug 24, 2009 | 05:28 PM
JDaniel's Avatar
JDaniel
Thanks, man! Im still workin it!
Old Aug 24, 2009 | 05:43 PM
jaygood's Avatar
jaygood
Very nice times
