Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Its Aliiiiive!
Old Nov 4, 2009 | 04:40 PM
simpleman68's Avatar
simpleman68
Default Its Aliiiiive!
517 / 484
Scott
Old Nov 4, 2009 | 05:03 PM
98vettedave's Avatar
98vettedave
Originally Posted by simpleman68
517 / 484
Scott
So tell us more about the set up,or is that top secret until Friday?
Old Nov 4, 2009 | 06:52 PM
pit-man's Avatar
pit-man
517 / 484
Scott
That's big numbers Scott !!
Pitt
Old Nov 4, 2009 | 08:55 PM
Tercel82's Avatar
Tercel82
Instead of hamsters. He upgraded to rabbits.
Old Nov 4, 2009 | 09:07 PM
camotruK's Avatar
camotruK
on dynojet or tune time?
Old Nov 4, 2009 | 09:46 PM
Fartpipe's Avatar
Fartpipe
Congrats simpleman.... i want some mid to low 10's from you sir!!!!!
Old Nov 5, 2009 | 08:09 AM
Blu's Avatar
Blu
Is this on the greedy Mustang Dyno?
Old Nov 5, 2009 | 08:42 AM
GARY2004Z06's Avatar
GARY2004Z06
Good numbers Scott.
Old Nov 5, 2009 | 12:19 PM
nickolbag's Avatar
nickolbag
I'm guessing no.
Thats good for 10.4s or better. Don't let us down Scott!!!
Old Nov 5, 2009 | 01:15 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
That's great Scott!!!
Cant wait to see you run.
Old Nov 5, 2009 | 08:33 PM
STEALTH 99 C5's Avatar
STEALTH 99 C5
Good luck with it Scott .
Old Nov 6, 2009 | 11:43 AM
LS1LT1's Avatar
LS1LT1
Nice numbers Scott, enjoy that new found powa.
Should easily be enough for that and at well over 132mph as well.
Old Nov 7, 2009 | 03:20 PM
simpleman68
Thanks all for the kind words.
Had a serious issue going on at the track and dumped a little over 1/2 quart of oil on the track through the catch can on the 2nd run in the burn box.
Tommy is working on it as we speak and will get me back up and running.
We're talking later after some preliminary tests. I'll post updates.
Quick run down of the day:
My first launch I wanted to come out real easy to see how the Spec twin was going to work with bias ply MTs (Thanks Nick )
Aired to 16psi, did a medium burn out and staged. Came out ~4k rpm and let the clutch out easy as I could and rolled into a granny 1.8x 60'.
I shifted around 6400-6500 and still ripped off a 10.9 at 131 with no seat time on this set up.
2nd launch, I aired down to 14 psi and came out ~4500rpm and cut a 1.6x and spun the nuts off the tires still. Gonna need to go a good bit lower if I'm going to be coming out well over 5k. I'm hoping the Spec twin with the bias plys and a few tweaks is going to be a magic combo. That, or I'm going to blow shet all over the track; we'll see.
Big thanks again to all who helped me out that day. Especially my one man pit crew, Chris (Tercel82)
Scott
Old Nov 7, 2009 | 05:08 PM
camotruK's Avatar
camotruK
i think the spinning on the 2nd pass was oil coming off the pass side catch can and leaking and going under your right rear tire...what it looked like in the vid too was that smoke was coming from that side of the car and possibly off the right rear tire
keep us updated on whats going on with it
Old Nov 7, 2009 | 05:12 PM
98vettedave
It's to bad that you didn't have time to do some shake down passes prior to yesterdays big get together. However,if the first pass you made is any indication of the cars real potential,then there is a whole lot left in that baby. Hopefully,we'll see some really good numbers in the weeks to come.
Old Nov 8, 2009 | 10:40 AM
Tercel82's Avatar
Tercel82
I think its time to make you race setup, so you don't need to wait for track rentals. Get you running more often.
Old Nov 10, 2009 | 09:36 AM
simpleman68
Update for the popcorn munchers.
Initial leak down tests came back within acceptable tolerances.
Going to put a couple hundred miles on her and retest to see if oil blows out at high rpms.
Will be retested in the next day or two to see if some miles will seat everything.
Scott
To Its Aliiiiive!
Old Nov 10, 2009 | 01:05 PM
j0n's Avatar
j0n
Old Nov 10, 2009 | 03:11 PM
robz's Avatar
robz
no.
Old Nov 17, 2009 | 12:33 AM
98vettedave
Scott
Hopefully,all is good now? Can you let us in on the root cause of the problem?
