Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Water Box
Old May 4, 2010 | 11:28 PM
motogib1's Avatar
motogib1
Default Water Box
I am planning on going to the track for the first time this year. I have an 02 coupe with H/C, stall converter, gears yada yada. Anyhow I've only run on street tires, drove around the water box. I'm now on MT ET streets. Question is: do you guys drive through the water box and do your burnout or do you drive around it and then back in to the box. Intuitively it seems to me that it would be preferably to back in and not drag water up to the starting line.
Thanks.
Old May 4, 2010 | 11:35 PM
USAFZ06's Avatar
USAFZ06
skinnies up front or stock fronts?
Old May 4, 2010 | 11:36 PM
motogib1's Avatar
motogib1
Stock tires up front.
Old May 5, 2010 | 12:42 AM
j0n's Avatar
j0n
Best bet is to back into the box with stock width fronts. Also when you say you're on mt et streets are you talking bias ply tires or the radials?
Old May 5, 2010 | 10:00 AM
zee OH sex's Avatar
zee OH sex
i would pull around, then back into the box.
usually, i pull around, back into the box, spin the tires quick, pull forward, do a healthy 1st gear burnout, then stage.
Old May 5, 2010 | 12:27 PM
chaase's Avatar
chaase
St. Jude Donor '12
I have stock tires up front and I just drive straight through the water box. It has never caused me a problem.
Old May 5, 2010 | 01:28 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I would back in also. But our track will not let me pull in!
Old May 5, 2010 | 06:00 PM
motogib1's Avatar
motogib1
I have the radials. Would be a lot easier to drive right through. Wasn't sure if it caused any problems.
Old May 5, 2010 | 09:44 PM
DragMan's Avatar
DragMan
I have done both ways with no issues either way!
Old May 5, 2010 | 10:11 PM
motogib1's Avatar
motogib1
Recommended tire pressure?
Old May 6, 2010 | 02:59 PM
99vetteran's Avatar
99vetteran
18-20 lbs is what I'm running
Old May 6, 2010 | 04:15 PM
chaase's Avatar
chaase
St. Jude Donor '12
Mine worked best at 18 cold. You may want to do some testing for your best set up.
Old May 6, 2010 | 11:06 PM
motogib1's Avatar
motogib1
Yep, went to the track tonight and did a couple of runs and took it real easy as this is a new setup for me. Ran pressure at 24 psi. Real gentle launches netted 12.02. I haven't been to the track for a year and a half so I even let off before I crossed the line. oops Haha, 1.88 60' at 115.6. Car has a lot left in her so I'm happy. I'll and run lower tire pressures and launch harder next time. Test and tune night. Thanks for the input.
To Water Box
