382 in work
St. Jude Donor '08
This pic is for Joey! Thanks fer suggesting the SFI flexplate B4 it was 2late...switched stock to this RPM SFI Flexplate...
Should be down in New Jersey @ Cartek for start up/Break in/Final Tune Mid July, will post results when I get em.
Damn, I need to do all the little stuff: Headers, comp ratio, cam, exhaust...ect. You guys are killin me.
Nice work Beer !! Are you coming to MIR-2 ??
pitt
St. Jude Donor '08
24 July E-Town may go, once everything is installed motor wise (should be done this weekend), it needs to go in to the body shop for some front work, while its apart I want to get rid of the years of frost heave and pothole issues on the front clip that have accumalated (replacing that front cradle piece, the previous owner welded poorly as well).
Hopefully there will be no show stoppers at Cartek (fuel system...wiring issues, you know the stuff you miss or don't think about
). If i shoot for Cartek say wednesday, tune Thursday/Fri I can hang out for the weekend @ Brielle NJ and make the event @ E-Town.Jim
St. Jude Donor '08
St. Jude Donor '08
Car fired right up, had 60 psi on the oil pressure and max coolant temp of 195 after about 15 minutes run time idle to 3000 rpms. No DTC's
Had issues messing with the Vararam Duct, I tried to relocate the MAF in front of the TB, but with the plate, it threw the spacing of the duct off (the arc of the duct is not in the right place). I pulled the plate system off, and will try again when the Vararam intake is fully in place for space out.
One of the Noids got hot, it was getting power from somewhere, when it should not have. I pulled the noids, and will revamp the nitrous system after the car is set up NA (probably single stage dry shot dual nozzle in vararam).
Waiting on the front clip (repair pothole/frost heave damage on bottom)to come back from the body man, then off to Cartek. On track for next week.
St. Jude Donor '08
Goals for the car are to run the 11.5 class (w/Hardtop on), and maybe get a 10.9x slip on Spray, while being "wife" drivable on 91 oct fuel.
Red exterior
White interior
LS1 V-8 modified professionally with Lunati 382 stroke kit
Custom head work, 2.02 / 1.57 valves, 64cc chambers, crane 1.8 rockers
Custom comp cam, 235 int. / 242 exh. .635 lift for int and exh
Slp headers / converters, flowmaster muffler
PTC 3800 stall, TCI built transmission
True GM 3.73 gears with Auburn gear posi unit
BMR sub frame and control arms
Nitto front tires / Nitto drag radial rear
Ed Wright (www.fastchip.com) tuned and dyno'd tuned engine making 481 rear
wheel and 518 foot lbs torque
Customer Pioneer player, amp, tweeters, and two 8" subs
