Race Specialty Designs is selling the best Line Loc on the planet.
Our unit does not hang the weight of the Solenoid on the brake lines. We have a black anodized aluminum bracket machined to fit right on the master cylinder mounting studs.
You do not have to remove or modify any of your stock brake lines when installing the RSD Line Loc. You don't have to round up any of the parts on your own, we include everything in the kit that you need, and then we ship it to you for only $250.
Order you C5 Line Loc here http://www.racespecialtydesigns.com/...&cat=38&page=1
Everything you need to install the RSD Line Loc is in the box for only $250 shipped. You only need to add your hand tools and some elbow grease.
You need this Mod if you want consistant 60' times. RichieRichZ06 was getting 1.6X 60' times on street tires because he could heat them up properly. No more one leggers, or single tire spin leaving the line because foot braking a burnout will never heat your tires as well or as evenly.
Be ready for race season with this easy to do yourself mod from RSD
