Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Ported Heads Hp gain
Old Mar 10, 2011 | 08:55 AM
turk2gk's Avatar
turk2gk
Default Ported Heads Hp gain
Hey i'm thinking about porting my ls6 heads. I was just wondering what kind of gains do you think I could possibly get in doing so?
Old Mar 10, 2011 | 04:45 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
While I'm not an engine building expert, I'll give you my .02
GM designed the cam with a certain airflow in mind. The heads were built around that airflow need - likely with a bit of extra flow built in. Porting the heads will certainly allow them to flow more air, but if your cam is not asking for more air, what good is it?
So you would likely get some increase in power with tuning, but you'll see more gains in a cam swap, than in porting the heads. Even more if you do both.
For example, I have un-ported LS2 heads on my car. These heads are virtually the same as the LS6 heads - just different valves. I had a valve job and a minor shave done to them to clean them up.
I'm at 454 RWHP and 409 RWTQ
Hope that helps..
Old Mar 10, 2011 | 05:32 PM
LS1LT1's Avatar
LS1LT1
If I were to pick just one (a cam swap or porting the heads while keeping the stock cam) I would CLEARLY do the cam instead.
Ideally, doing both will show some nice gains.
Old Mar 10, 2011 | 11:24 PM
BuddhaZ06's Avatar
BuddhaZ06
Hope that helps..
what cam and cubic inch do you have?? im kind of looking to get that kind of rwhp out of my setup
Old Mar 11, 2011 | 01:16 AM
firefighter813x's Avatar
firefighter813x
Hope that helps..
So what cam are you running? That will tell everything.
Old Mar 11, 2011 | 09:23 AM
turk2gk's Avatar
turk2gk
Hope that helps..
Sweet! Thanks for the info. I already have headers and cam. I just cant justify putting afr heads on the car for 4 grand when I can just purchase an A&A procharger and get wayyy more with that. So i was just seeing if porting the heads would be worth anything
Old Mar 11, 2011 | 09:30 AM
simpleman68's Avatar
simpleman68
You may be able to get a blower for that kinda coin, but people always forget all the extra expenses that accompany that kind of modification.
Bigger injectors, boost a pump, gauges, tubing, intake and the list goes on.
Heads and cam are a very good bang for the buck in this way.
Scott
Old Mar 11, 2011 | 11:00 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
I have the ECS big NA cam in a 346 ci LS1.
If you already have the cam, then porting the heads should get you a nice gain.
There are several good vendors on here that can port your heads.
Old Mar 11, 2011 | 11:13 AM
simpleman68
And even some nice folks selling slightly used heads/cam packages that will make huge increases in power.
Scott
To Ported Heads Hp gain
