how to get burnout rubber off ti exhaust?
would post in general section but they dont do burnouts there. here's what i have tried so far that doesnt work. heat small torch, goof off, bug and tar remover, various metal polishes, compound medium breaks a little bit loose, brake cleaner barely cuts it, wd 40 , only thing that works somewhat is gasoline and its a lot of rubbing. will try airplane paint stripper tommorrow. anybody got a solution. dont want to use a wire wheel either. like us racers id like something that will cut the rubber loose with a gooid et.
after paint stripper gunk is next. reason i doint want to use wire wheel is the ti's are sold. the corsa extremes just put on friday night and yielded 1 mph over in the 1/4 plus they sound evil
I was using under the hood years ago, spraying WD 40 on the carburator linkage.
The intake was hot enough to cause an intense flash fire.
By the time I smothered it, the vacume hoses & such were melted
big time.
no way the muffler will get hot enough to ignite the wd 40
airplane paint stripper and gunk engine cleaner doesnt work. gasoline only solution thus far and i got 99% off so far and with flitz metal polish on a cotton buff in drill is getting the rest off slowly but there looking good for the effort.
