Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
New Engine is in!
Old Apr 5, 2011 | 07:48 PM
Rob Petyo's Avatar
Rob Petyo
an ls2 TB would be a big help for now
When you have the re tune, ask about the flow rate of the injectors
Old Apr 5, 2011 | 08:55 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by WKMCD
If your tuner told you that 1 7/8 LT's and 3 inch x-pipe drops your RWT reading....you seriously need to find a new tuner. I agree that the numbers are very low. I would expect that setup - even with the smallish cam for a 383 - to be closer to 470RWHP or so.
I agree. I can see losing torque with 3in exhaust and 1 7/8 headers on a 346 but not on a 383. I serious think he got a 346 and should pull the heads and measure the bores if he can't find his lost power.
Old Apr 5, 2011 | 09:21 PM
Toxiclemonade's Avatar
Toxiclemonade
Something smells fishy here...you sure its a 383?
Old Apr 5, 2011 | 09:30 PM
WKMCD's Avatar
WKMCD
For a 383 he'd want to measure the stroke.
Old Apr 5, 2011 | 11:56 PM
All_Motor_C5LS6
Instead of a 3.89 bore as found on a 346cid, isn't the bore on a 383 around 3.92?
Old Apr 6, 2011 | 07:22 AM
pit-man's Avatar
pit-man
As far as I know, the stroker kit goes in the stock bore, however I think they do have an oversize kit that is slightly larger in bore size.
Old Apr 6, 2011 | 07:23 AM
paint it black vette's Avatar
382 = 4.000 crank and stock bore 3.900
Old Apr 12, 2011 | 09:39 PM
LightFighter_GXP's Avatar
LightFighter_GXP
With stock LS1 intake and TB ....... stock bottom end I make 430... with FAST ported intake and TB I make 458 with Stock 346 bottom end.... with that 383 I would think you should be way north of 450!!!
Old Apr 12, 2011 | 09:42 PM
LightFighter_GXP
if you got a new block then you have stock bore........but if your using the old block then I would say its atleast .010 over
