Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Dyno Results
Old May 8, 2011 | 07:21 PM
chad156's Avatar
chad156
Default Dyno Results
Picked up a 2004 Z16 Z06 about a month ago.
Inspection, the only thing I can see done is a cat back exhaust, no mufflers, but bends and look like resonators where the mufflers should be, so they are not straight pipes.
Took it to a dyno day and I was surprised by the numbers. It was around 1:30 PM and 88-90 degrees out.
I put down 381.9 RWHP.
Seem right? or would you assume there is cam work?
Old May 8, 2011 | 07:36 PM
pit-man's Avatar
pit-man
From what I saw in the past, 370 was the norm for a tune so with the exhaust you should be right on.
Old May 11, 2011 | 07:16 PM
bearcatt's Avatar
bearcatt
Not to shabby.
To Dyno Results
