could this head be a contender ??
Here is what I've found out about them;
LSX/L92 #19201807
• L92/LS3 port configuration
• Produces from 356-T6 Aluminum with 5/8” thick deck
• 6 Bolts per cylinder, Aluminum construction
• Runners are in “as cast” condition
• 250cc intake port and 80cc exhaust port
• 70cc Chamber size
• Intake flow = 280 CFM@.600 / Exh flow= 180 CFM@.700
• Assembled with 2.00” Intake and 1.555” Exhaust Valves
• Beehive springs
• 15 Degree valve angle
• 3.890” minimum bore size block
• Uses LS3 / L92 rocker arms
• Requires the LS3 / L92 intake manifold
Does anyone have real world experiance with them ?? Flowed on a 3.90 bench ?? Porting possibilities ?? And of course, comparisons to other popular small bore heads ??
Thanks.....
Uses 11mm (10) and 8mm (13) head bolts (not included)
Accommodates production valvetrain components (except for Drag Race and Circle Track heads)
Includes premium beehive-type valve springs (except for Drag Race and Circle Track heads)
Extra material cast in the port areas to accommodate professional porting
Valve guides for 8mm valve stems
Racing-specific LSX-DR (Drag Racing) and LSX-CT (Circle Track) heads feature raised runner designs and other unique features designed to maximize performance at the track.
This is a link to the Tech section about these heads......
http://forums.corvetteforum.com/c5-t...nder-head.html
