Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
a little theoretic preview discussion
Old Jul 3, 2011 | 02:33 PM
Underdogg's Avatar
Underdogg
Default a little theoretic preview discussion
there are 2 cars, a 01 Z06 and a 03 3LZ.
01 Z06 mods are as follows-
vararam b2 with power duct
90mm tb
fast 92
afr205 heads unmilled
EG mayhem II
lt headers
x pipe w cats
stock ti cat back
shifter
mcleod twin disk
built rpm trans
mt et streets
dyno tune from EG
lg adj coilovers
03 3LZ mods are as follows-
vararam b2 w power duct
90mm tb
92 fast
tfs 215cnc heads unmilled
EG whiplash II
lt headers
x pipe w cats
flowmaster cat back
shifter
upgraded clutch and flywheel
Z06 shaft
4.10 rear end gear
nitto 555r dr 305s
EG dynotune
now, with the only thing different between these 2 real world cars besides the supension and the 410s, which car would be more likely to win in a heads up 1/4 mile race given those being the only real significant differences in the 2 set ups?
assuming the drivers are of equal skill and having both gone to about the same driving schools. the same entry level road course class to get you familiar with the car.
both cars will eventually have spray but neither will be spraying for this race because all it takes is a bigger jet size theoretically and that car wins.
i guess what im gettning at, all dyno numbers aside, which set up will be the better "race car" for the quarter mile?
Old Jul 3, 2011 | 04:10 PM
hardcore4sure's Avatar
hardcore4sure
What type of headers, or do they both have the same? What is the upgrade to the clutch and flywheel? Is it a aluminum lightweight like Fidanza?
Old Jul 3, 2011 | 05:23 PM
Underdogg's Avatar
Underdogg
I know the base has kooks. Not sure on size. I wanna say the Z06 has 7/8 American racing.
It is a lightweight flywheel. The brand is unknown as it came installed with the purchase of the car.
Old Jul 3, 2011 | 06:31 PM
hardcore4sure
Id have to say Kooks and AR is a wash so the advantage would have to go with the base because the 4.10's (better than the Z06 tranny gearing) and the TFS heads generally out perform the AFR's unless they've been touched up by Tony Mamo. If the upgrade to the clutch has a lighter flywheel the base should have a slight HP edge as long as both FAST set ups are the same, ported or unported. The Z06 might stand up to more continuous abuse with the twin disk clutch and built tranny. It would definitely be close and totally depend on traction on launch. The Z06 should be able to launch harder with coil overs an ET streets, but if you can leave clean on 4.10s you will have a good shot. Overall it will be a door to door race but I would have to say slight edge for the Coupe given equal drivers.
Old Jul 3, 2011 | 07:43 PM
Underdogg's Avatar
Underdogg
I will see if I can bring a vid camera when this race goes down. We have been debating on this race for a couple months while both the cars have been getting worked on. But this up coming week, both builds will be coming to being close to being done. The base will be back tues or wed. Depending on parts the Z06 may take a little while longer but not too much longer. This will happen very soon. Should be a very interesting run or two. We all agree that the 60ft times will be the deciding factor. And will definitely be one for the slow motion finish line cam.
Old Jul 5, 2011 | 12:55 PM
R6cowboy's Avatar
R6cowboy
The base '03 seems it would have the power advantage; bigger cam (Whiplash II > Mayhem II) and the TFS heads probably slightly outflow the AFR. And the '03 has a little bit higher gearing with the 4.10's vs the Z06 M12 trans and 3.42 gears, but not much. The gearing between to two is so close I really don't think it would make much of a difference at all being H/C cars. But the Z06 has a slight "launch" advantage with the adjustable coilovers and a small weight advantage I assume. Man, its almost too close to call. But to answer your question which is better for the 1/4 mile, my guess goes to the Z06.
Old Jul 5, 2011 | 01:06 PM
DANZGLASS's Avatar
DANZGLASS
total drivers race.
Old Jul 5, 2011 | 01:51 PM
StonaPipeZ2004Z06's Avatar
StonaPipeZ2004Z06
01Z06. He'll be able to launch harder on ET Streets than the 3LZ on nitto's.
Old Jul 5, 2011 | 05:55 PM
Underdogg's Avatar
Underdogg
Originally Posted by DANZGLASS
total drivers race.
this where im at on this one myself. its so close to even from the modding aspect of it i think it will be a matter of reaction times and 60ft numbers
Old Jul 6, 2011 | 10:09 PM
Underdogg's Avatar
Underdogg
found out today that in fact the 01Z06 will be intalling a 102mm tb as well as 102mm fast instead of the 90/92mm he bought a week ago. wonder what will happen now??
Old Jul 7, 2011 | 09:13 AM
98vettedave's Avatar
98vettedave
No big advantage there. As a matter of fact with limited cubic inches (346) the 102mm TB will most likely result in less torque down low than the 90/92 combo.
Old Jul 7, 2011 | 10:10 AM
Tsab's Avatar
Tsab
If I were a betting man, the Z06..... mostly due to the fact of the built trans and dual clutch allows for a harder launch. With good drag tires you could do quite well.
Old Jul 7, 2011 | 10:13 AM
Tsab's Avatar
Tsab
Yep, if I were racing it I would launch at 5k RPM or there abouts. With a well prep'ed track you should get a 60' time in the 1.5 / 1.6 range.
Old Jul 8, 2011 | 12:34 AM
p1bz's Avatar
p1bz
It takes a modded base to touch a stock Z, now put same mods on Z and it walks the base. No question about it, car for car, the Z and on E.T. streets and a good smooth clutch, c'mon..........
I see these guys have EG cams, are they in Houston? PM me I'd like a piece.
Old Jul 8, 2011 | 01:12 AM
StonaPipeZ2004Z06
OHSNAPCALLOUT!!!!!!!
Old Jul 8, 2011 | 05:33 AM
RC45's Avatar
RC45
What exactly is a 2003 3LZ?
Old Jul 8, 2011 | 11:36 AM
98vettedave
Can't say that I agree with your logic when comparing a modded coupe to a modded Z06. When you change the heads,cam,intake and exhaust on both vettes the original advantage that the Z had no longer exists...both should make close to identical power when using the same components. The Z will still have a weight advantage if the cars are untouched...no real advantage to either car when considering traction if running on the same wheels and tires.
To a little theoretic preview discussion
Old Jul 8, 2011 | 03:54 PM
Underdogg's Avatar
Underdogg
It's the trim package. The base has selective ride control, fog lights, HUD, memory seats... All the bells and whistles. Just to reference any weight differences in the 2 cars. Which is only 130 lbs. The driver of the 01Z06 has more weight that that on his person, so we will just call the car weights an even stalemate lol
Old Jul 8, 2011 | 07:00 PM
Underdogg's Avatar
Underdogg
with you having a 2 stg n20 setup i dont see that being a very fair race.
besides, its a friendly race and there is no money involved. its just a race for fun between two co-workers who just so happen to be gear heads with c5's
Old Jul 9, 2011 | 12:06 AM
KyleGernentz's Avatar
KyleGernentz
Default I find this a very interesting thread indeed......
Since I'm the owner if the 2001 Z-06 in question! It is truly a friendly race amongst coworkers. I'm having "England Green" Install :
1) Tony Mamo 102 FAST Intake and 102 throttle Body
2) AFR 205 CNC Heads (Used Heads so Stephen and Steve are going to kill me before it's over I'm sure)
3) Yella Terra Rockers
4) 60lb Siemens Flow Matched Injectors
5) Patriot Extreme .650 Dual Springs
6) Stephen's Excellent as always Super Tune
I have no clue what the final numbers will be but Damn this is fun... May the Real fun begin soon.......
