Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Gremlins in the Wire
Old Aug 9, 2011 | 08:29 PM
LightFighter_GXP's Avatar
LightFighter_GXP
Default Gremlins in the Wire
my ABS service, traction system is acting up..... okay prob a wheel sensor
Left head light sticking shut...... every now and then... PITA
Steering Collum lock is also acting up..... got stuck on me twice I managed to free it ...... so I decided not to drive ..... I ordered a bypass just waiting for that to arrive
when it rains it pours!!!
Old Aug 9, 2011 | 10:10 PM
sami85L98's Avatar
sami85L98
SWPS thats what you meed, same exact problem last christmas, i even dont have column lock bypass and did the sWPS, easy 4-5 hrs of job but you dont have to rush though. so far after 5k no problems.
GL and search for SWPS you get lots of info install procedure...so on.
Old Aug 10, 2011 | 02:50 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I had the same problem. Replaced the steering wheel sensor - went away. cheap fix...
Old Aug 11, 2011 | 02:13 AM
LightFighter_GXP
I'm getting wheel sensor codes.... nothing with the SWPS so I'm going check the connections once i get my CLB installed
Old Aug 14, 2011 | 09:32 PM
LightFighter_GXP
collum lock is fixed what a PITA after messing around with the motor for a good 30 mins I finally got it to retract...... if you haven't done the CLB I suggest you do so
To Gremlins in the Wire
