Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
z06 60 foot
Old Aug 20, 2011 | 12:12 AM
homeless's Avatar
homeless
Default z06 60 foot
Just bought a 2003 z06 car has cai and headers. I put a set of drag radials on it and off to the 1/8 mile i go.Well its harder than i thought .I done a good burnout but the best i got was a 1.90 sixty foot 8.08 at 92.53 mph. But the car is still spinning.Guess i need more seat time.What et should the car run with the mph thanks for any input
Old Aug 20, 2011 | 08:00 PM
Silnus's Avatar
Silnus
That MPH is pretty good man, really good. What kind of radials? What was the DA when you ran, you can check on the site that provides the info (cant rememeber link). Do you have an x-pipe or catback? IF it is just headers nad CAI, that is a solid mph but the e.t. can def go down looking at the 60'. I say 7.8x @ 93 with a 1.8 60'.
Old Aug 20, 2011 | 08:46 PM
homeless's Avatar
homeless
Nitto 305-35-18 about wore out. dont know da and high flow cats and bullet cat back.The car would never dead hook.Went down to 18 lbs in tires
Old Aug 22, 2011 | 02:39 PM
04goatman's Avatar
04goatman
Try some MT - ET streets, that will have you below under 8's 1/8th mile. What RPM were you launching it?
Old Aug 22, 2011 | 04:17 PM
homeless's Avatar
homeless
Default 60 ft
I would leave any where between 2800 and 4000 rpm. Let tires down to 18 lbs. May have been a slick track because seem like everybody had some problems. Also first time out in car. My other vetts have been automatics. Had tires really hot on the 1.90 pass but about 2 cars out tires would start spinning a little
Old Aug 23, 2011 | 10:32 AM
04goatman's Avatar
04goatman
My suggestion is to pick a consistent RPM to launch from, and a set tire PSI. Do that for about 3 passes and then make a small change to one of the factors (probably tires). Honestly a 1.9 is not the worst 60 foot, for your first time out with your Z06. Its not the easiest car to launch first time at the track. just my 2 pennies.
Old Aug 26, 2011 | 02:24 AM
Silnus's Avatar
Silnus
Nitto DR are good but like stated above, you cant go wrong with Mickey T's. Best hooking tire IMO. Get the radials, the ET streets are damn near a full slick. You will dead hook and launch it around 3500. Should bring that 60' down to 1.70's easy.
Old Aug 27, 2011 | 07:28 AM
homeless's Avatar
homeless
Default 60 foot
Went to a different track last night.Just got to make one pass.Tires at 18 lbs left line at 3500 rpm slipped clutch about 10 feet.Went a 1.86 60 ft 8.06 at 91 mph.Need more seat time only second time out in car.
Old Oct 2, 2011 | 08:04 AM
homeless's Avatar
homeless
Got to make one more 1/8 mile pass in car last night.Still on the nitto dr It went a 1.90 sixty foot and a 7.99 at 92.68 mph. Only 4 th pass in car i belive it will go some 80 with more seat time .But the best part was a guy with a c6 z06 called me out he was on street tires. Had fun waxing his tail
Old Oct 2, 2011 | 08:29 AM
ajrothm's Avatar
ajrothm
Nittos work pretty decent when new but after some time, their traction drops big time....even if there is still some rubber/tread left on em....
A fresh set would do wonders for you....or better yet some ET Street radials.... But if you drive it all the time, stick with some fresh nittos...
No way you can practice good launch techniques when your tires are worn out....
Old Dec 10, 2011 | 07:22 AM
homeless's Avatar
homeless
I got to make one more pass.I have added a torquer 3 cam,same tires it went a 1.77 60 ft 4.91 330 ft then when i went to 3rd it would not go. Clutch stayed on the floor so i coasted across the line still run a 8.04 at 60 mph. I belive the car was on a 7.50 run. I have video if i can figure out how to put it on here.
To z06 60 foot
