Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Is 600 HP+ overkill?
Old Sep 2, 2011 | 03:17 PM
Blow Torch's Avatar
Blow Torch
It's not really overkill, but you don't need it to have fun.
I have more than that, my wife has less than that, and they are both a ball to drive
Old Sep 2, 2011 | 04:33 PM
z06holeshot's Avatar
z06holeshot
2nd Gear
http://www.youtube.com/watch?v=mxTAb...layer_embedded
Old Sep 2, 2011 | 08:45 PM
C6Vette2009's Avatar
C6Vette2009
Do what you can afford! It's really that simply. If your pocket book can handle it, then do it [600+ HP], if that's what you want.
Old Sep 3, 2011 | 10:52 PM
LSOHOLIC's Avatar
LSOHOLIC
Originally Posted by joshtownsend
It you have traction issues at any amount of power..you cant drive.period.. I laugh so hard at most of the guys that say "I have 500 hp and spin though 4th gear".. bottom line is your trying to spin and that's retarded... same principal in getting gears.. gears makes a car better, regardless of the application.. I make ...well, its not important what i make, but if i run 3.90 and 20's on the back and don't have a traction issue, then 99% should not either..
You posted in another thread you went 11.0@138, is this correct? --PRE-ZO6
Know that is some funny sh*t !!
Old Sep 4, 2011 | 08:34 AM
robz's Avatar
robz
Originally Posted by vennum
I have heard that it is difficult to keep from breaking traction and other mechanical parts when you exceed 600 HP.
With that being said, is it worth it to have more than 600 HP?
It sure sounds better to say "I have over 600 HP" but it also gets more pricey too.
You have to make more modifications to sustain the 600+ HP like clutch, rear end, transmission, even the studs on the rear have to be upgraded or they can be shreaded off.
In most situations you may not be able to stay on the road I would think.
What do you guys think, specially those of you who own a car with that type of power?
Not bashing, just wondering if it is worth the extra money that goes into attaining that goal.
It's overkill.
Old Sep 5, 2011 | 07:57 AM
simpleman68's Avatar
simpleman68
He still hasn't come back to respond to the call out.
Scott
Old Sep 8, 2011 | 12:22 AM
jaguar5822's Avatar
jaguar5822
Save the money, keep the car at a reasonably inexpensive level and buy a used liter bike for when you get used to the car's power.
Old Sep 10, 2011 | 08:59 PM
PMPNSEZ's Avatar
PMPNSEZ
Long and short of it...500 is technically too fast for the streets. Remember I said "technically," however, things sure do start getting fun and interesting when you're over 600. You'll find yourself out on the prowl looking for street bikes. Not that I've ever done such a thing lol
Old Sep 10, 2011 | 10:39 PM
Tsab's Avatar
Tsab
600 plus can be ok if the build is done right. The thing is that, the higher up the HP ladder you go, the more maintenence is required. Also, if you build the motor to 600 plus hp, the rest of the drive train needs to be upgraded to handle the power. So in the long run you need to think about the "Whole" package, not just one aspect.
Old Sep 11, 2011 | 10:42 AM
simpleman68
Yeah, but you're rockin' the 6000 SUX; so what are you worried about?
Scott
Old Sep 11, 2011 | 01:38 PM
nickolbag's Avatar
nickolbag
Yea its overkill but still fun!
Old Sep 11, 2011 | 05:17 PM
Tsab's Avatar
Tsab
Scott
Thats right its an American Tradition. You think you hate now, but wait till you drive it.
Old Sep 11, 2011 | 05:38 PM
  #33
simpleman68
"They see me rollin', and they hatin'"
Scott
Old Sep 12, 2011 | 04:48 PM
  #34
Chicago1's Avatar
Chicago1
Some people think a stock c5 is fast so the term "fast" or "overkill" will be different to everyone else. If you can afford it go for it. Piece the right parts together know somewhat what the **** your getting into and have fun with it.
Old Sep 14, 2011 | 01:29 PM
  #35
roythomas's Avatar
roythomas
well there you go !! this tells you this group is ballin $$$$ stay away with 600 anything
Old Sep 23, 2011 | 09:03 PM
  #36
easyvette's Avatar
easyvette
Yep I fall into the fools catagory. I like having over 600hp a smash away. But you are correct it does make driving the car very interesting at times.. I think the key is to have the rear to support it. Otherwise its pins and needles on launching the car....
****EDIT special note. Let me get back into the garage to finish replacing the motor.
Old Sep 27, 2011 | 08:17 AM
  #37
4SFED Z's Avatar
4SFED Z
Dont be afraid to boost.
1st: Know your budget
2nd: Find a good installer/tuner
3rd: Talk to your installer/tuner on the build
4rd: Build it to where its reliable
Remember, you can always go with the largest pulley first to keep the boost down. Later down the road you can always pulley down.
Dont forget to factor in a fuel system as well
To Is 600 HP+ overkill?
Old Oct 16, 2011 | 06:24 PM
  #38
99FRC Newb's Avatar
99FRC Newb
Originally Posted by stonabones69
Yup, then 700 feels good til you drive 800
thats why i'm skipping 700, 800, and 900. trying to jump straight from 600 to 1000.
Old Oct 16, 2011 | 07:05 PM
  #39
zblkr1's Avatar
zblkr1
great minds think alike
i have a 03 z06 for cruising around and an 09 yamaha R1 for the thrill. Nothing on 4 wheels will come close to the rush you get on 2
Old Nov 4, 2011 | 01:32 PM
  #40
vettandtyphoon1's Avatar
vettandtyphoon1
When I hit the 500hp mark on my turbo Busa. I said that's fast enough.
With that being said I'm aiming for north of 1000 in the vette
