Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
too tall for track?
Old Sep 7, 2011 | 08:30 PM
BuddhaZ06's Avatar
BuddhaZ06
Default too tall for track?
im going to the track friday and just got my homemade drag pack all together, and i have the car lowered very far, and i figured i'd put it back up a lil bit for the track for weight transfer. is this too tall in the rear? it might also settle a little. i pulled it up about 15 feet and backed it back up. any input is appreciated! thanks
here it is after messing with it a little and driving a couple miles. better?
Old Sep 7, 2011 | 10:03 PM
LS1LT1's Avatar
LS1LT1
Yeah I think that might be a little too high, could mess with your launch and even possibly unsettle the car a bit after a few feet out and/or on the 1-2 shift.
Is there inner fender liner rubbing (there shouldn't be if they're only 26" tall) if you lower it?
Old Sep 8, 2011 | 10:55 AM
BuddhaZ06's Avatar
BuddhaZ06
Nah it won't rub at all. Is being bottomed out okay though? Figured it'd kill weight transfer
Old Sep 8, 2011 | 12:12 PM
LS1LT1's Avatar
LS1LT1
No, sitting on the bolt stops/bottoming them out isn't good either.
That could create a hook/unhook/hook situation that is both detrimental to sixty foots and possibly even dangerous.
Are your bushings/rubber stops that worn out?
I know most C5 (and even C6) guys that still retain their stock suspension/stock shocks etc do lower the rear of their cars a little bit in attempt to aid traction.
Old Sep 8, 2011 | 12:40 PM
BuddhaZ06's Avatar
BuddhaZ06
I think its bottomed out through the shocks. I Thought I've heard that's how the bottom out. Not sure on rubber stops though.
Old Sep 8, 2011 | 08:13 PM
BuddhaZ06's Avatar
BuddhaZ06
is this better?
Old Sep 9, 2011 | 10:36 AM
robz's Avatar
robz
is this better?
I wouldn't worry about too high. Make sure nothing hits or rubs and you should be fine. And slicks grow so you want some fudge factored in.
Old Sep 9, 2011 | 12:49 PM
pit-man's Avatar
pit-man
Mine sits that high and it doesn't seem to have any affect on launching as Rob says above.
Old Sep 10, 2011 | 06:49 PM
BuddhaZ06's Avatar
BuddhaZ06
it worked out pretty good. still gotta work on my launch. only pulled a 1.66 60'. i pulled that a long time ago, but i've only got about 4 passes with this setup. still learning the car.
Old Sep 10, 2011 | 08:22 PM
pit-man's Avatar
pit-man
1.66 s starting to get down there
Old Sep 10, 2011 | 09:13 PM
BuddhaZ06's Avatar
BuddhaZ06
i ran a 1.66, 1.67, 1.82, and a 1.71 last night. my personal best is a 1.64. i did that with vararam, slicks, tune, and 4.10's. i now have h/c/i along with that. actually im still in need of a tune. havent gotten it tuned since i put ls7 manifolds on it
my best from last night. 11.6@122
http://www.youtube.com/watch?v=MifOXVDsQV4
Old Sep 12, 2011 | 05:30 PM
ajrothm's Avatar
ajrothm
Budda are you running spacers on the front with the GTO spares? I have the same front combo and havent put them on yet.....I am thinking I will need 1" spacers for it to look right?
Old Sep 12, 2011 | 07:42 PM
BuddhaZ06's Avatar
BuddhaZ06
i put 2" spacers on. i think 1" to 1-1/2" would still look okay. 1" might be a lil in still. i liked how the 2" looked so i went with it.
Old Sep 13, 2011 | 08:33 PM
ajrothm's Avatar
ajrothm
Did you have to change studs? what brand are the spacers?
Old Sep 14, 2011 | 08:41 AM
BuddhaZ06's Avatar
BuddhaZ06
Nope don't need studs. EBay has a ton of them.
To too tall for track?
