Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Fast 90 and LS2 results
Old Jan 15, 2012 | 05:48 PM
Lifted07Sierra's Avatar
Lifted07Sierra
Default Fast 90 and LS2 results
Ok so for most of you who have been following my dyno results, I got the Fast 90 and ported LS2 TB tested.
Car picked up 8rwhp and 8lbs but the gains started at about 4000rpm, Ill try and get a dyno graph posted up next week.
Final numbers were like 389/387
This is a full bolt on LS1 with shorty headers instead of LTs and stage 2.5 PRC 5.3 heads, on a STOCK 2000 cam.
So I guess its safe to say that a fast intake is more valuable on a LS engine that has a bigger cam in it.
Atleast this will give you guys that dont have cam or heads that a fast is not worth the money until it is your last bolt on mod
Old Jan 15, 2012 | 08:13 PM
mchicia1's Avatar
mchicia1
Yup, your bottleneck is now the cam. The good news is that even a tiny cam will give you tremendous gains.
Old Jan 15, 2012 | 08:28 PM
Lifted07Sierra
Geoff spec'd a 226/230 LSA 113 + 2 for me so thats probably what Im going with
Old Jan 22, 2012 | 03:59 AM
Breze84's Avatar
Breze84
Seems like that was a huge waste of money for you then just to pick up 8/8...
Old Jan 22, 2012 | 08:24 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I wouldn't say that at all. He's adding parts and taking notice of the gains as he goes.
On his way to a finished product. This is good info.
It might be a waste of money for someone to just add a fast 90/90 to a stock engine, but this is not the case here.
I'm looking forward to the new numbers with the cam install.
Old Jan 22, 2012 | 11:22 AM
pit-man's Avatar
pit-man
It will be interesting since a lot of us do every thing all at once and don't really know single item results for sure.
Old Jan 22, 2012 | 01:57 PM
Lifted07Sierra
Word to what the other two above my post said.
I could've done everything at once I guess but it really isn't costing me much more to do it this way. In fact its allowed me to pick up a used fast, used ported ls2 tb and other stuff.
This is also why I went backwards with doing heads instead of a cam first. I just wanted people to see what it would do for their cars since there isn't a lot of data on doing it this way.
I was going to not do headers until after the cam but Im going to go ahead and replace my shorties with some LTs and see what it does.
I just replaced my 75mm MAF with an 85. Havent taken it out yet but I need to get the new maf tables loaded.
I won't be dynoing this one mod but from 3 other threads I found on less modded LS1s the bigger MAF gained 4rwhp on all of them.
Old Jan 22, 2012 | 01:59 PM
Breze84's Avatar
Breze84
Reading error on my part, For some reason I though you had a cam already... My bad...
Old Jan 22, 2012 | 02:01 PM
Lifted07Sierra
No problem buddy, I bet my 226/230 cam will put me over 450 easy. After the LTs of course.
If I were to do it over again I would've spent the extra $200 for the ported LS6 heads instead of the 5.3 just for that extra 10rwhp that they seem to do over the 5.3
Old Jan 22, 2012 | 02:14 PM
Breze84's Avatar
Breze84
Ya you should have no problem, I want to do the MS4 or the T-Rex Cam... Its go big or go home
Old Jan 23, 2012 | 03:37 AM
hardcore4sure's Avatar
hardcore4sure
Your providing good step by step info for those who wondered what each mod is worth individually, in the end you will have a stout combo
To Fast 90 and LS2 results
