Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
First Time at track
Old Mar 4, 2012 | 09:07 PM
bmech's Avatar
bmech
Default First Time at track
2002 C5 Conv MN6
RT=.640
60'=1.9
330=5.319 MPH 68.08
8.102 1/8th @ 86.17
How does this stack up? I bought this used and trying to figure out if stock
Blackwing CAI
Borila stinger exhaust.
Old Mar 5, 2012 | 12:32 AM
LS1LT1's Avatar
LS1LT1
Originally Posted by bmech
2002 C5 Conv MN6
RT=.640
60'=1.9
330=5.319 MPH 68.08
8.102 1/8th @ 86.17
Blackwing CAI
Well, if it has a CAI/filter and a cat back exhaust on it then it's definitely not stock either way, but you're also not sure if it has more mods (cam etc.) or not?
That looks like it's would work out to roughly a 12.6/12.7 in the 1/4 mile at around 110mph. And that 1.9 sixty foot is pretty good for true street tires as well, if all it has is the CAI and Borla that is.
Old Mar 5, 2012 | 09:12 AM
mchicia1's Avatar
mchicia1
That is great for mostly stock...now get to a 1/4 mile track .
Old Mar 5, 2012 | 11:29 AM
bmech's Avatar
bmech
What I know is exhaust is stock except Stingers(Stock manifolds, H-pipe,cats.). Heads are 241 casting. It does not apear front of motor has been apart no marks on the bolts. I have new non run flat Firestone Firehawks. I expected to run in the upper 8s but was suprised. I know I need a new clutch it was slipping on the second run when I hit 2nd and 3rd. And I dont think I can run 1/4 with out a cage due the soft top?
Old Mar 5, 2012 | 05:12 PM
LS1LT1's Avatar
LS1LT1
Yes, all late 2000 and up LS1 motors had the 241s I believe.
It depends on the track but likely not unfortunately, the convertible rule is anything running 13.49 or quicker must have at least a 5 point roll bar and harness.
To First Time at track
