Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Drag radials
Old May 3, 2012 | 06:29 PM
Txboatman's Avatar
Txboatman
Default Drag radials
Finally got rid of my runflats and went with a shorter MT D/R. 245/40/18
Thinking 20 psi should be the magic number but any input would be appriciated. Car is lightly modded, exhaust/vararam/tune. This will be my first run with a tune on the car. Prior to that the car went 12.92 @108 with a 1.97 60' spinning off the line. Am I close to the PSI I need with 20 psi. It feels good on the street.
Old May 3, 2012 | 07:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
That's a reasonable place to start.
Run as much pressure as you can without excessive wheel spin.
Old May 3, 2012 | 07:19 PM
robz's Avatar
robz
It all depends on hoe you plan to launch. If you do a full burnout, I might start a little higher.
Old May 3, 2012 | 09:05 PM
Txboatman's Avatar
Txboatman
I should clairify, I am running a A4.
To Drag radials
