Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
SD vs MAF performance discussion....
Old May 27, 2012 | 03:34 PM
LSOHOLIC's Avatar
LSOHOLIC
Default SD vs MAF performance discussion....
I'm relatively new to tuning my car and would like to discuss the pro's and con's of either tune.
Where I race we get a DA swing from -1500 to +3500 through out the year. And with my novice tuning tenure I feel the "card style" MAF tune would suit me better...??.. I personally feel if my tuning abilities were up to par, a SD tune that I could log and adjust at the track would be the best for ET's....??...
For those that run a SD tune, do you guys adjust for fuel table every trip to the track (depending on the DA & grains) ??
Just looking to discuss the topic further..........I also picked up some reading material to help me understand this stuff (Greg Banish & Dan Maslic).
Thanks............fyi, the inlet consists of a 4" tube from the vararam, so a card MAF should not be close to maxed if that option is used.
Old May 28, 2012 | 03:06 PM
LSOHOLIC's Avatar
LSOHOLIC
Anyone with firsthand knowledge on this ??
Or theories on which tune favors certain conditions ??
Or examples of a SD tune in the summer with fuel maps looking "fat" when the air gets better in the fall/winter ??
Thanks.......
Old May 28, 2012 | 04:12 PM
PRAY's Avatar
PRAY
I went from the MAF to a OLSD COS3 tune. I was maxed out though so I gained quite a bit of power. When you use the COS3 you can use the IAT sensor to adjust fueling so you don't have to worry about the retunes. I had a large cam and what not so being able to command what ever fuel I wanted was highly beneficial.
Old May 28, 2012 | 06:09 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
I'm SD and race in Canada and even as far as South Carolina.
No adjustments to the tune needed.
Old May 31, 2012 | 09:57 PM
LSOHOLIC's Avatar
LSOHOLIC
Thanks for the explanation.....When I get a better handle on the tuning, I think a SD tune would be the "quickest" option. Log a run and make "real time" adjustment in the pits.
But for the novice tuner that I am (if I can even be considered novice...lol) I feel the card MAF will be better suited for right now.
How did most of you guys become component in the tuning arena ?? Just time behind the laptop ?? Or a class ?? Or what ??
Thanks........
Old May 31, 2012 | 10:30 PM
LSOHOLIC's Avatar
LSOHOLIC
I don't understand completely.......If your SD tune was "setup" in the heat of the summer at....lets say +2500 DA, then you race at ATCO in December in -1500 DA what would your fuel tables look like, that December day at ATCO ??
So I guess my question is, what about density correction ??
I would think that a "boosted" atmosphere would be the best scenario for a SD tune. But what about nasty NA setups ??
Thanks.............
Old Jun 1, 2012 | 02:03 PM
PRAY's Avatar
PRAY
Time behind the lap top bro. Just building a variety of nasty rides and having to figure out how to make them run right. Plus I DD all my combos as do my customers so I needed them to run right. Trial and error and lot of reading on the tuning forums.
Old Jun 1, 2012 | 09:26 PM
LSOHOLIC's Avatar
LSOHOLIC
10-4.....what it boils down to is.....the nearest competent tuner is a 5 hour drive (one way).. That being said, the car is sd tuned by "him" but with "him" being so far I'm kind of forced to learn it for myself. The car is a case study in the evolution process...lol. And as I'm able to apply the power I will keep adding some...therefor I need to get a handle on the software architecture and tune.
Thanks for the feedback......guess its time to hangout on the HP forum...and read...a lot !!
Old Jun 2, 2012 | 09:49 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
Mine runs 9s with an SD tune that hasn't' been touched since it was set up. Unless you're making changes to the car you shouldn't need to retune.
Old Jun 3, 2012 | 10:15 AM
vrybad's Avatar
vrybad
I ran OLSD on my car, and spent the time to log, log, log.
My car ran perfect no matter the temp, whether in cold fall/winter or the heat of the summer.
AF ratios were always within proper parameters no matter the weather.
I'm guessing HPT has some additional tuning that can be done beyond my old tune, but it worked very well for me.
I think it has to do with how thorough you are with the overall tune.
Old Jun 3, 2012 | 04:50 PM
LSOHOLIC's Avatar
LSOHOLIC
[QUOTE=mdaniel;1580973798]Mine runs 9s with an SD tune that hasn't' been touched since it was set up. Unless you're making changes to the car you shouldn't need to retune.[/QUOTE
Thanks for the response....but, in my situation it does not seem very logical..... You/we/us speed tons of money to get the last 5-10hp out of our cars then we SD tune it in the summer +2500 DA and run that tune year round...effectively giving up hp in the winter when she leans out.... Or vise versa winter to summer...
Not sure where you live...but a stab in the dark tells me Michigan. Summer DA at Milan drag strip is in the +2500 range and in the fall she can drop to -2000......can you please explain how you compensate for density correction ??
I agree with the 12.8 to 13.1 range for N/A. The only thing that I will add is that these cars perform better at different A/F ratios depending on what gear you are in (and acceleration rate). It takes a bunch of logging and ET slips to figure out the "sweet spot". DA also becomes a factor." It's not perfect like a lot of people want to make it. It is just a point of reference. You have to actually test to find what your vehicle likes. The MPH on your time slip is the answer when tuning for the DA.
Do not take this as an attack...I'm just playing the devils advocate.....in an attempt to learn the "real" pro's and con's of the "tunes", with all out et/performance in mind. Not just a "fun" daily driver....
And FYI, this Maslic book is the ****... Dude seems real sharp.....
Thanks..........
Old Jun 3, 2012 | 06:34 PM
mourat's Avatar
mourat
I think keep MAF unless you need to get rid of it. I'd even say upgrade to Z06 MAF, they just work so well and simplify tuning so much, why get rid of what works?
I still believe you should get SD tables right down low (below 4k) in all MAP vs. RPM ranges especially if you are runing dynamic ve. However I wouldn't get rid of a MAF unless you are exceeding it. As for runing Open loop, I believe in Open loop, just need to dyno tune for it on a Mustang or other Eddy Dyno.
Old Jun 7, 2012 | 11:40 AM
TurboLX's Avatar
TurboLX
Ideally, both the MAF and SD calculations should come up with the same number for airflow (and individual cylinder air charge). The trick is that MAF sensors are great for large, steady flows and SD excels at transient conditions where the instantaneous flow at the MAF sensor may be unsteady but the individual cylinder filling events are more consistent. Each method has its own strengths and weaknesses, which is why the factory GM calibrations use both. It allows them to get the best of both worlds, each at the right time. Tuners who turn one of the two off are often making a tradeoff for ease of tuning at the possible expense of accuracy under some conditions.
Old Jun 7, 2012 | 03:59 PM
mourat's Avatar
mourat
Well put! When it comes to transient conditions MAF just can't be accurate when its constantly measuring compared to a preset table.
Old Jun 7, 2012 | 08:09 PM
LSOHOLIC's Avatar
LSOHOLIC
Wow....."the man" shows up in my thread....
So will "HP" or "EFI" allow you to tune both parameters ?? Or am I miss understanding the concept ??
Hey Greg, it would be nice if you would do a class in this part of the country....the Dallas area. I'm sure it would be a big hit...
Thanks..........
Old Jun 8, 2012 | 02:03 AM
SBCGENII's Avatar
SBCGENII
The Map is a pressure sensnor. You change altitude so does your Map reading. Gm has built a few SD only cars. Dont take it like you should never check up on your tune though. Most people who tune their own cars tweak them constantly. You can get a WOT tune done in a day but everything below that will take longer especially with the large cams.
Old Jun 8, 2012 | 02:11 AM
SBCGENII's Avatar
SBCGENII
Yes they will.
Old Jun 12, 2012 | 01:56 PM
TurboLX's Avatar
TurboLX
Yes. Most popular tuning software packages have access to everything you'd need to recalibrate each model independent of the other. There are "switches" in the software that we use to force the system to only operate on one airflow model at a time. The object is usually to calibrate each airflow model separately (but accurately!) and then restore the "blended" performance where it has the option to work with both of them. It can take a decent amount of time, but the result are almost always better.
I get a lot of requests for local classes and it's just hard to keep up when I have a day job. This is a big reason why I went through all the trouble to start making the DVDs so people could save on travel costs and still get world class training at reasonable prices. I will be adding more videos in the future, which will be available through many CF vendors.
Old Jun 12, 2012 | 05:50 PM
vrybad's Avatar
vrybad
Taking my car as an example, since I know how I tuned my car:
When I ran OLSD, I road tuned for hundreds of miles.
For instance, I night be on an open section of highway at 40mph in 4th gear.
Or the back roads.
I would take time to log as I leaned into and out of the gas.
Then I would drop to 3rd gear, at 40mph, the same speed, and load the engine up and down in 3rd, then to 2nd gear at 40mph, and really build a log of AFR's across a broad rpm and load range.
IMO, the key to building a good SD map is to load each gear and try to hit as many cells as possible.
Best done on a dyno, provided you can get the proper airflow across the engine/cooling system.
Greg,
What you are saying is that my car may have run even better had I re-enabled the MAF?
I wasn't really sure how to do it effectively, so I never tried it.
My fault.
To SD vs MAF performance discussion....
