Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
C5 mods dyno results
Old May 27, 2012 | 09:32 PM
IamGov's Avatar
IamGov
Cruising
Default C5 mods dyno results
LS1
Weiand Aluminum Manifold
Cold air induction, duel filter
80mm Throttle Body
Mass flow
Cam
Injectors
Long tube headers
Straight pipe
Corsa exhaust
Professional custom tune
Non HP addition
High performance clutch assembly
Results turned 420 at the wheels
Power band was 6450
Torque at rear was 423
Still awaiting track times, thinking mid 11's if I can connect
Old May 28, 2012 | 08:20 AM
pit-man's Avatar
pit-man
Originally Posted by IamGov
LS1
80mm Throttle Body
Mass flow
Cam
Injectors
Long tube headers
Straight pipe
Corsa exhaust
Non HP addition
Power band was 6450
that should be close
Old May 28, 2012 | 09:37 AM
nomrlz's Avatar
nomrlz
nice #'s. should run that if it hooks
Old Jun 1, 2012 | 07:22 PM
98tadriver's Avatar
98tadriver
get rid of that aluminum heatsink and put a LS6 or a FAST intake on it
Old Jun 9, 2012 | 12:35 PM
baxsom's Avatar
baxsom
what cam? stock heads?
Old Jun 9, 2012 | 05:13 PM
Breze84's Avatar
Breze84
LS1
80mm Throttle Body
Mass flow
Cam
Injectors
Long tube headers
Straight pipe
Corsa exhaust
Non HP addition
Power band was 6450
2 worst things you could have ever put on your car!!!!
To C5 mods dyno results
