Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
What will it run ...
Old Jun 1, 2012 | 05:04 PM
Rob Petyo's Avatar
Rob Petyo
Default What will it run ...
In the Fall - decent air - 100 shot
Old Jun 1, 2012 | 05:23 PM
pit-man's Avatar
pit-man
What is your data now ?
Old Jun 1, 2012 | 05:26 PM
Rob Petyo's Avatar
Rob Petyo
10.48 @ 126 N/A
346 Ci (stock bottom except rod bolts)
... i feel it might have a 10.3X in it N/A ...
Old Jun 1, 2012 | 05:49 PM
paint it black vette's Avatar
dec track rental. nine time and a good pass you'll skip 9.9 and be in a 9.8 et. speed my guess is 137 maybe a little more. turn on in first gear and leave on. i will tell rpm turned on that worked for me
Old Jun 1, 2012 | 06:50 PM
pit-man's Avatar
pit-man
I think that 100 shot at your level will give you 4-5 tenths
Old Jun 1, 2012 | 07:47 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Old Jun 1, 2012 | 07:53 PM
LSOHOLIC's Avatar
LSOHOLIC
Spill the beans for us nitrous junkies....
Method of activation ??
Method of distribution ??
Timing control ??
Plug ??
Fuel side ??
Dry or wet ??
Launch control ??
etc...etc....If you can't tell....I like the details in these types of builds.
The answer all depends on how fast you bring it in and at what %.
What clutch and tire ??
Thanks....and cant wait to hear the results.....
Old Jun 1, 2012 | 08:06 PM
Rob Petyo's Avatar
Rob Petyo
Timing control ??
Plug ??
Fuel side ??
Dry or wet ??
Launch control ??
It's a Nitrogen Assisted Nitrous Oxide (NANO) System. Pressurized by the smaller tank which carries 3000 psi and regurelated / distributes 950psi to the Nitrous bottle for a constant pressure through the whole run.
Ligenfelter 2-step pulling 2*
NGK-7's
I'm an auto so it's foot-braked (best 60 so far n/a is a 1.37).
Tire is 255/50/16 Hoosier 26"
wet:
Old Jun 1, 2012 | 08:13 PM
Rob Petyo's Avatar
Rob Petyo
^^ fuel side - upgraded - (with in-line kenny bell)
Old Jun 1, 2012 | 08:27 PM
pit-man's Avatar
pit-man
All you Auto vettes are knockin down some low sixty foot times. Geeze.
Old Jun 1, 2012 | 08:42 PM
LSOHOLIC's Avatar
LSOHOLIC
NGK-7's
wet:
Looks great..........
I'm a nano guy also.....
1)TPS switch for activation ?
2)LNC-003 or -002...timing controller/progressive + 2 step ? How are you de-energising it ? MPH switch or just a momentary switch ?
3)Looks like a single nozzle....safety wired to a stand off ? To keep the torque/anti-rotation to a minimum.
4)Looks like your pulling fuel from the rail, what fuel when your spraying it ?
How quick are you bring it it ?? RPM ?? window switch on the top end between shifts ??
.......Edit......
Thanks.....keep us updated. And that 60' is awesome
Old Jun 1, 2012 | 09:30 PM
Rob Petyo's Avatar
Rob Petyo
Yes, TPS switch
LNC-002... launching and timing controller
momentary switch
Like this idea, "single nozzle....safety wired to a stand off ? To keep the torque/anti-rotation to a minimum."
Yes, pulling fuel from the rail, I try to run a 3-2 mixture of gas, probably switching to Torco by fall
It's a Harris window switch that seems to have a lot of options ... right now, I'm more trying to run the 10.50 number then to play too much with it. Having it coming on now in second at a rmp a bit higher than my stall - off- then hit third.
What kind of numbers do you have with the beauty in the video?
Old Jun 1, 2012 | 10:37 PM
LSOHOLIC's Avatar
LSOHOLIC
Yes, TPS switch
momentary switch
lol....the video is Lingenfelters "shop" car they do testing on...and compete in some of the LSX races. They were going 8.90's last year at full gen 5 weight. 3600lb +...wow...
your convertor will make a huge difference in the efficiency of the spray. Cuz the more you add the more she will want to blow through the convertor. Whats your convertor % slippage raw ??
Whats your gear ??
Are you planning on stepping up the rollout dia ?? As you know she will rpm quicker...effectively "shortening your gear".
What RPM do you go through at, raw ??
BTW, what are the specs on your convertor ??
But all in all I would expect .06-.09 and obviously the sooner you bring it the better the et results...with traction. But bringing it in that late will be a fun top end charge. Bring it in on the launch and I see some mid/high 9's in your future....especially with the killer DA that area brings in the winter.
Thanks..........be care ful of the nozzle "turning" during applied power. The plugs should tell the story....
Old Jun 1, 2012 | 10:58 PM
Rob Petyo's Avatar
Rob Petyo
Don't know the convertor % slippage - it's a Yank 4000
Gears are 3:73's
"shortening your gear" may become a problem ... I'll could just spray through fourth ... maybe a higher tire ... but I really like the 26' running N/A, RPM currently shifts at 6800
You need to get to the track buddy and get some times you can compare to. . . what do you think you will 1/4 mile now?
Old Jun 1, 2012 | 11:54 PM
Fartpipe's Avatar
Fartpipe
well I will say it will run "FAST"
Old Jun 2, 2012 | 12:04 AM
LSOHOLIC's Avatar
LSOHOLIC
Gears are 3:73's
Sorry I'm not keeping up with your responses...my 6 year old son and I were in the process of beating the new Mario Bros...and we did....he is so excited....lol. The simple thing sure make their day...lol.
OK, the gears will help the motor respond to the spray and help your mph with the tire size. Would you feel comfortable raising the rpm limit ?? I maybe wrong but I feel you will be pushing the limit of that tire with the torque spike when its hit. A bias ply may be in your future if you get real serious about nitrous....especially if you plan on hitting it before 330'...which IMHO, you should. Here is work for me in the past, 30% off the line then ramp in the remainder in .07 of a second. So, 30hp (30%) off the line and ramping the 70hp (70% which =100%) with in .07 seconds...so you will be all in at .07 seconds.
I'm not sure what I would run raw...I hate bench racing my own combo. But the facts are....edit.....
Thanks............when are you expecting to make your first passes ?? The fall is to far wawy...lol
Old Jun 2, 2012 | 12:29 AM
nomrlz's Avatar
nomrlz
if you can spray from the green. i can see a 100shot pickin up 6tenths. just a matter if it will hold it out of the hole
To What will it run ...
Old Jun 2, 2012 | 04:01 AM
LS1LT1's Avatar
LS1LT1
Definite potential for some solid high 9s Rob if it all comes together.
Old Jun 2, 2012 | 11:48 PM
LSOHOLIC's Avatar
LSOHOLIC
Hey Mr Hot_Wheels....what can you get out of your Yank 4000 ?? Raw with that 346 ?? Will it "really" stall 4000 with that small of motor ?? And what can you "flash" out of it ??
Trying to get an idea of how "tight" it is. Tighter the better for the jug....
Also, are you running a brake in the trans ??
Thanks.........
Old Jun 3, 2012 | 07:37 AM
Rob Petyo's Avatar
Rob Petyo
^^^ LSOHOLIC
The best 60' (so far) with the Yank 4000 is a 1.37
It will stall over three (3k), much more and I tend to push the skinny's but I like to be around 2200 keeping torque on the trans...
I realize the tighter the better but, also like the N/A 60 foots so there's a compromise going on here, we'll see how much next Saturday when I run the 10.50 index.
NO brake in the trans - N/A motors are so quick you don't need one
typical 60' is a 1.41 - 1.43, mine is on the right:
