Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Weight Question
Old Jan 26, 2013 | 08:15 PM
Kingman99's Avatar
Kingman99
Default Weight Question
From time to time an article will mention that due to the use of another
Material the part will save 10 lbs. Or the new model will be 125 lbs lighter!
What does all of this mean if anything? Also how much weight loss would a C5 need to make a difference?
I weigh 150 lbs say l race an identical vette only the driver weights 250lbs does this mean l have an advantage?
Or l have 2 gallons in my tank and the other guy has a full tank where a gallon of fuel weighs 8lbs.
This seems to me nothing more then mental masturbation!
Old Jan 26, 2013 | 08:41 PM
Tar Heel's Avatar
Tar Heel
IIRC the rule of thumb is that every 100 lbs. = 0.1 in ET which in drag racing is a big difference. That is assuming of course that you're comparing apples for apples. Also, when you can remove reciprocating weight (axles, wheels, tires, cranks, ...) i.e. anything that moves and requires energy to spin you are gaining "free horsepower" since it would take less energy to move less weight.
Old Jan 26, 2013 | 10:09 PM
123sugey's Avatar
123sugey
Dig
I'm at a point once my DM kicks in and my Z is as fast as can be with a solid 60' time (1.3xx) I want to be 2850 lbs.
Weight makes a difference in ALL racing. I would suggest driving your car to the best of your ability FIRST then weight reductions
Old Jan 26, 2013 | 11:35 PM
Supercharged111's Avatar
Supercharged111
It may not seem like much, but last time I weighed my car it only had 1/4 tank. I forgot the number, but I believe I calculated the weight to be, with a full tank, 3140#. Because of that I'm semi-obsessed with getting it below 3100# with a full tank. Headers, clutch, and battery seem like great ways to get there, but coughing up the money is another thing. If you're not racing for time, then you likely won't notice it just screwing off on the street. The buttometer isn't as sensitive as a dyno or 1/4 mile.
Old Jan 27, 2013 | 08:56 AM
Kingman99's Avatar
Kingman99
Default Weight reduction!
Hi
Thanks guys it all makes sense.
Alan
Old Jan 28, 2013 | 11:11 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Why do you think all horse jockeys weigh in at around 100 -125 lbs ???---FREE SPEED
Old Feb 11, 2013 | 03:22 AM
steven31371's Avatar
steven31371
put lighter seats in ;-)
I saved close to 40 lbs this way
fixed headlights will save you close to 20 lbs
Old Feb 11, 2013 | 09:35 AM
Kingman99's Avatar
Kingman99
Default Lose Weight
it is better and cheaper just to lose some weight by dieting!
Old Feb 26, 2013 | 10:46 PM
steven31371
Haha....True Dat
I've shed about 180 lbs off of the running weight of my car, it helped acceleration, but more importantly, the whole car just feels more alive in every way, more agile around curves, braking, and accel...hard to describe, but it just really woke the car up as total driving experience.
haha...I'm sure a diet for my fat azz would do the same thing!
Old Feb 26, 2013 | 11:43 PM
123sugey's Avatar
123sugey
Dig
[QUOTE=steven31371;1583091026]put lighter seats in ;-)
What seats did you end up using ?
Old Feb 26, 2013 | 11:50 PM
steven31371
I went with the Bimarco Futura
is big enough to fit me (6'3" and 240 lbs) and small enough to fit in the narrow seat tunnel of the car without cutting or modding.
To Weight Question
