Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
First Supercharged run
Old Feb 17, 2013 | 01:00 AM
Speedaemonc4's Avatar
Speedaemonc4
Default First Supercharged run
Just finished upgrading to a procharged ls2 setup, havent dynoed but went to the track Friday night and jumped straight onto the track running an 11.8 at 134 into a cold front head wind. On the second run got a 11.6 at 132, thinkin I need some better tires, running Nitto NT-01s right now, had a 1.9 60ft on the first run, 2.0 on the second. My old turbo setup was fun but the instant power from the procharger sure make me smile bigger,
Old Feb 17, 2013 | 08:09 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
My car is in the middle of having a A&A kit installed right now, I'm looking forward to that first time behind the wheel. Sound like yours is running really sweet.
Old Feb 17, 2013 | 09:02 PM
evo2ls1's Avatar
evo2ls1
great mph, I just finished my FRC with bolt ons and A&A kit, made 3 passes car ran 11.6, 11.3, and 11.2 between 129-130, you have a fast ride sir trapping 134!
Old Feb 18, 2013 | 07:00 AM
pit-man's Avatar
pit-man
You will be in the 10's with some good rubber
Old Feb 19, 2013 | 10:35 PM
danieloneil01's Avatar
danieloneil01
Great mph but jesus that time blows even with that sixty. Post your slip. If you can't hit the 10's with DRs then you need to sell the car. 1.9 isn't bad with that much power on street tires so you should be able to run deep into the 10's with DRs.
Old Feb 20, 2013 | 12:14 AM
RonSSNova's Avatar
RonSSNova
6 speed?
Old Mar 12, 2013 | 04:11 PM
MONSTAA_C5's Avatar
MONSTAA_C5
You're going to love the new-found power. I haven't put enough miles on to get used to it yet. Drives normal until you build 3k rpm and hammer it!
Old Apr 12, 2013 | 10:02 AM
LSX_NUT's Avatar
LSX_NUT
Way to be a douche man. Maybe he was taking it easy on the shifting because his drivetrain isn't built yet or that he was spinning all the way down the track. Cut the guy some slack.
To First Supercharged run
