Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Burning oil
Old Mar 15, 2013 | 11:09 PM
esco50anniversary's Avatar
esco50anniversary
Default Burning oil
I have a 2003 50 anniversary and I run mobile 1 full synthetic oil and I drive it like a vette needs to be driven. It's burning about one quart every 4000 miles. Is anyone else having this problem and should I b concerned??
Old Mar 16, 2013 | 12:52 PM
ZZOOM06's Avatar
ZZOOM06
I quart every 4k miles is NOT a problem, especially if you drive the car hard. If it was using a quart every 1000/1500 miles I would be concerned. Just drive the wheels off it and change the oil every 4k miles,,,,,problem solved!
Old Mar 16, 2013 | 04:52 PM
pit-man's Avatar
pit-man
Both my strokers use a quart every 1000 miles
Old Mar 16, 2013 | 05:36 PM
esco50anniversary
Ok cool nice to know I've never seen a drop of oil in the garage so just curious
Thanks for feedback
Old Mar 30, 2013 | 01:37 PM
FourG63 97GST's Avatar
FourG63 97GST
yea that sounds about right, put a catch can on it if you havent already
Old Apr 18, 2013 | 02:21 AM
KristaHolland's Avatar
KristaHolland
2nd Gear
Default Thank you
yup even I face the same problem and also searching for the solution so, if anyone aware of any better solution, please let me know
Old Apr 20, 2013 | 10:53 AM
Tuffguy610's Avatar
Tuffguy610
Do you have a catch can installed on your PCV system? I'd be willing to bet that the oil you are consuming is caused hy "blow-by" (oil that is taken from the crankcase to your intake via the PCV system). When the oil gets into your intake it is burned as it goes into your combustion chambers. This is a common problem with the LS motors
To Burning oil
