Hey guys, I just installed kooks 1 7/8 LT's (annoying install), vararam intake & power duct, kooks 3" cat less exhaust, borla stingers and mgw short throw.. Trying to get a good base number that I should see with a good tune on the dyno? And what my car should run in a 1/4? Going to rkt or Jeff Lowry for tune. Any other bolt-ons like lighter flywheel, rockers or valve springs, fast90 ported or unported, shaner s2 TB or any tb maf suggestions.. Spark plugs, even small things that'll help me launch or help my 60ft.. sway bar, or even anything small bolted that you think is worth the money and will give me better numbers at the track, would help! Appreciate it. Trying to get every inch of power out of her just bolt ons and tires.
Just so seeing because I keep reading different numbers. Some say 370ish hp some say 385ishhp. So I'd like to know a pretty good number range.
New to the vette world, had an 06 cam only goat 445hp/395torque. LS cars only.
What car do you have? If you have an 02-04 ZO6, with the current mods you mentioned + dyno tune, 375-390ish RWHP is typical (SAE on dynojet). I made 386/372 SAE with a Halltech, 1 7/8" AR LTs, and a tune.
04 z. That's the numbers I've been hearing. Just want to make sure because this guy told me with his tune it would be 370ish hp. 369 tq. Thanks for the reply. Hearing different setups with a few other add ons could help make 380-390.
