Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Moser rear sub frame kit
Old Jul 31, 2013 | 09:13 PM
l88rocket's Avatar
l88rocket
Default Moser rear sub frame kit
Anyone use the Moser sub frame kit? faster, better than a stock rear end?
Old Aug 1, 2013 | 12:39 AM
123sugey's Avatar
123sugey
Dig
I like it but keeping a stick car a stick is the problem
Old Aug 17, 2013 | 04:37 PM
l88rocket's Avatar
l88rocket
Have you installed it? I thought about trying to put the trans on the back of the motor like usual
Old Aug 17, 2013 | 07:23 PM
Tar Heel's Avatar
Tar Heel
My buddy told me about this on the phone today and I looked it up. Boy, what a nice piece! We run Stock Eliminator which is exactly what this was designed for. Slate's car (if you look on the web site) leaves hard with it. I'm considering going that route eventually and putting a Jerico behind the LS1 (literally behind) as soon as I find $10K+ sitting around somewhere. I'd have to say it's more than we could bite off it our 2-garage and would take a reputable chassis shop to install and make sure everything was square and true and solid. Yes, there are many IRS cars running very quick but that 12-bolt set-up sure is sexy!!!
Scott
Old Aug 17, 2013 | 07:25 PM
Tar Heel's Avatar
Tar Heel
Also, I would think putting a traditional manual transmission behind the engine would be easier due to size than an automatic. I'm guessing the tunnel would have to be extensively modified with an auto due to the size of the case. Something like a Jerico would be more narrow and maybe easier to install.
Scott
Old Aug 20, 2013 | 03:49 PM
robert miller's Avatar
robert miller
Scott
It would be all the same to me only diff just a bigger cut in the floor with a auto, then to fix it back.
To Moser rear sub frame kit
