Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Factory freak 01 z06?
Old Aug 19, 2013 | 06:15 PM
C 5's Avatar
C 5
No Time!
Default Factory freak 01 z06?
I know factory freaks arent as common as they were ages ago, and I was told there are no "factory freaks" anymore, but either the low reading dyno in the area was not calibrated or something is going on here.
Long story short, I traded in my 06 GTO (full bolt ons) that dynoed 364/370 for an 01 Z06, it was BONE STOCK when I bought it, had 21,000 miles. I since put a SLP Blackwing, and got a dyno tune. on the same dyno as the GTO I pulled 359/360 in hot and humid weather, First time I went to the quarter, spun bad and ended up short shifting to second and netted 12.5 @ 114. the car is stock with the exception of a CAI and a dyno tune, this dyno is a dynapack dyno that reads a bit lower than most dyno shops. So what is this? a spike or false reading, or a potential factory freak? Also another factor that might come into play is the correction factor, it was set to none on the dyno.
Old Aug 19, 2013 | 07:17 PM
MX621's Avatar
MX621
Cai/tune on a 01 with a 114 trap is dead on. My 02 trapped 116 in august ne weather showroom stock.
Old Aug 20, 2013 | 08:31 AM
95rtturbo's Avatar
95rtturbo
Dynapack dynos typically read higher (although 359WHP doesn't seem out of line for an 01 ZO6 with a CAI / dyno tune). Also, yes the correction factor would definitely have something to do with it as well. Agree with the above, your trap speed is right where it should be. No factory freak.
Old Aug 20, 2013 | 10:11 AM
Blow Torch's Avatar
Blow Torch
Sounds about right to me.....
Old Aug 20, 2013 | 01:57 PM
Rob Petyo's Avatar
Rob Petyo
those Z06's are all freaks if you ask me
Old Aug 20, 2013 | 03:44 PM
mchicia1's Avatar
mchicia1
Why would you think that is a factory freak?
Old Aug 20, 2013 | 04:32 PM
LT-1 kid's Avatar
LT-1 kid
sounds normal, 02-04 are a bit faster.
Old Aug 21, 2013 | 12:13 AM
BuddhaZ06's Avatar
BuddhaZ06
Roughly what my 01 ran with CAI and no mufflers and no tune. With tires I ran 11.9@115. 113mph bone stock
Old Aug 21, 2013 | 12:47 AM
LoneStarZ06's Avatar
LoneStarZ06
Went to dyno today and I tink I came up with factry freak also....
I bought a 03 C5 Z06 with 115k miles just under a month ago. I have not done anything to it. As far as I can tell everything is stock except for straight pipes from the factory cats.
It produced380whp and 369Tq
Old Aug 21, 2013 | 01:10 AM
BuddhaZ06's Avatar
BuddhaZ06
I was thinking some 02-04 cars dyno'd 370-380 stock depending on dyno
Old Aug 22, 2013 | 04:07 PM
Jims Z06's Avatar
Jims Z06
Stock with LT's my 04 Z was 384hp/377tq
Old Aug 22, 2013 | 11:47 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
That sounds like a freak to me...2001 are rated at 385 (engine) HP!
I did a run on a mobile Dynojet this weekend with a 02 Z06 (80,000 miles) stock except with Borla XR1 cat back and Twin cone intake (no tune) and pulled 356 RWHP and 348 TQ. I thought it should have been higher. I pulled up to the rev limiter (6600-6700 RPM)
Old Aug 23, 2013 | 12:49 AM
C 5's Avatar
C 5
No Time!
maybe usually, but this is known as a low reading dyno in the area, my goat made 364rwhp there, when it was making 38X on dynojets and several other dynoes, the fact that the Z dynoed so close within that is what confuses me.
Old Aug 23, 2013 | 02:41 AM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
Dyno numbers are way way overrated, easily manipulated from one to the other.
1/4 numbers and trap speeds are a different story however.
Old Aug 25, 2013 | 06:42 PM
m6 c5's Avatar
m6 c5
Well My dads 02 z with longtubes and a CAI hit 366 on a dynapack after it was tuned, later on in the day I saw an 04 hit 359 with just a CAI.
Old Aug 25, 2013 | 10:38 PM
marvinseah's Avatar
marvinseah
I think some dyno's these days are factory freaks and not the other way around. Lol!
Old Aug 25, 2013 | 11:42 PM
SBCGENII's Avatar
SBCGENII
Cad bone stock RWHP & RWTQ (Auto + Manl) (all dyno types):
RWHP-RWTQ----Trans----Locale----Owner-------------Date-------------Dyno
425------425------auto------Tex-------wfo--------------05-05-10--------Dynojet
429------423------auto------Ind-------wait4me--------12-10-08---------Dynojet
429------430------auto------Cal-------Gary Wells------09-26-09--------Dynojet
430-------???------auto------Nev-------Zippy------------??-??-??--'09---Dynojet
436------432------auto------uae-------Tagzo------------12-17-09-------Dynojet
438------432------auto------Ohio-----Dr.Buzz----------??-??-09---------Dynojet
439------435------auto------Nev-------Zippy------------06-14-10--'10--Dynojet
439------436------auto------Txs-------Dmsz06---------10-05-10--------Dynojet
440------427------auto------Cal-------cts-v-twin-------02-19-10--------Dynojet
442------442------auto------Cal-------Kat McRat-------07-20-09--------Dynojet
444------442------auto------Fla-------Veelocity--------03-18-10--------Dynojet
447------450------auto------Ill--------Prof---------------04-03-10-------Dynojet
451------439------auto------Txs-------richeic77--------02-25-10--------Dynojet
454------453------auto------????------mafungu---------05-03-09-------Dynojet
457------448------manl-----Tex-------stealthjr---------07-10-09--------Dynojet
457------459------auto------Flor------Low ET----------10-07-09--------Dynojet
459------459------auto------Tex-------Nine Ball------- 12-07-09--------Dynojet
459------462------auto------Ariz------Mike 09 V-------01-27-10--------Dynojet
460------461------auto------NC--------Heintz Rac------02-18-10--------Dynojet
462------445------auto------Md-------tmc cl65---------05-05-10--------Dynojet
462------501------manl------Ill--------Razorecko------05-01-09--------Mustang
463------461------auto------Ne--------intrvnton302---04-16-10---------Dynojet
465------447------auto------Tex-------richeic77--------01-26-10--------Dynojet
466------463------auto------NC--------Heintz Rac------03-18-10--------Dynojet
466------464------manl-----Cal--------Luna-------------05-??-09-----Land&Sea
470------465------manl-----uae-------venom ws7-----04-20-10--------Dynojet
471------475------auto------Tex------Dave Golder-----01-07-09--------Dynojet
474------481------auto------Tex-------J Campbell------02-22-10--------Dynojet
491------496------manl-----Md--------Tbjs--------------04-20-10-----Dynapack
493------511------manl-----Cal--------fleadh------------04-28-10----Dynapack
493------519------auto------Cal-------D3 (Craig)-------01-29-09-----Dynapack
494------483------manl-----Tex-------Silver –V-------- 01-16-09-------Dynojet
498------515------auto------Cal-------Gary Wells------ 01-16-09-----Dynapack
500------481------manl-----Ala-------roarkb------------03-06-10-------Dynojet
502------490------manl-----Tex------TrevorD----------12-25-09--------Dynojet
507------525------manl-----Ind------backup------------09-26-09------Dynomite
525------519------manl-----NY-------aj660-------------10-22-10------Dynomite
http://ls1tech.com/forums/dynamomete...l#post13977203
Dyno numbers don't mean much.
To Factory freak 01 z06?
Old Aug 26, 2013 | 01:12 AM
Breze84's Avatar
Breze84
My 01 was/is a factory freak... Same was with my 04 GTO... Everybody knows about that car on LS1GTO lol...
Put down 367/364 right after a catback/CAI C6Z put down 435rwhp... Back then my car would trap mid 117's stock...
Car now with just Cam, Full exhaust and tune makes 440/408 and traps 124 in 3000+DA
Old Aug 26, 2013 | 12:43 PM
SBCGENII's Avatar
SBCGENII
Quite a few trap 117....
C5 Z06 Bone-Stock Times
1--11.783 @ 116.90--1.818--J-Rod---------'02
2--11.818 @ 117.26--1.783--Ranger--------'02 11/03 Slip
3--11.844 @ 117.91--1.761--Gary2004Z06-'04 12/07 Post 229, Slip
4--11.93x @ 119.xx--1.xxx --Esoteric-------'0x
5--11.97x @ 118.80--1.90x--GMHTP--------'04 03/04
6--11.99x @ 117.61--1.xxx --02Z06Racer---'02
7--12.048 @ 115.92--1.866--pwrshfd-------'02 12/03
8--12.074 @ 119.18--1.860--02EBzEE------'02 10/11 Post #36
9--12.08x @ 115.95--1.83x--Pray ----------'02 01/06 Slip
10-12.09x @ xxx.xx --1.79x--UVETTA -------'03
12.131 @ 120.65--1.970--zapp109-----'04 03/09 Slip, Post #384
12.205 @ 117.96--1.91x--Nat04Z06 ----'04
Old Aug 26, 2013 | 01:34 PM
95rtturbo's Avatar
95rtturbo
Not 01s, which is what Breze84 has.
