new personal best
Best run of the evening was 11.74 @ 113 with a 1.53 60'. Car is basically a bolt-on with a stock lift and stock duration Bullet Pure Stock cam. It was very consistent running an 11.74, 11.75 and 11.77 despite us playing with tire pressures and not attempting to cool it at all except ice on the intake.
We run Hoosier 27" x 11" x 16" DOT drag radials. Tire pressure was adjusted from 23psi all the way down to 18psi and 60' times never changed. I was very surprised by that.
Finally, if you believe drag race times and their density altitude calculator conversions at sea level (we'll see those conditions later this fall) the 11.74 would translate to an 11.49. Car is still at full weight other than wheels/tires.
Scott
Unless you log everything, it is just a big guess.
Keep the tire pressure as high as you can without spinning. Lower pressure can slow you down.
No need for ice on the plastic intake. It never gets hot enough to make a difference.
Electric water pump is a good idea.
Good luck vs the import crowd...
Weren't able to take pictures racing (when my wife drove it was just lifting the front tires) but we did snap these. We'll get some the next time we're out in the day.
Edit: Think i found it. Are these the rules? http://www.mydigitalpublication.com/....php?id=949427
Do you need to go any faster?
What weight reduction mods have you done ?? Also, what does your exhaust system currently consist of ??
Again, congrats on getting out and enjoying your car !!
AIR CLEANER: Optional. Build custom ram air with or without filter
BLOCK: Must be OEM for horsepower claimed. No filled blocks. Deck block for compression, Might be able to modify for better bay to bay breathing
BRAKES: Must be OEM complete, Line lock accepted. OEM up grades allowed. upgrade to oem smaller and lighter rotors cailpers. or turn the stock ones down to save weight
BUMPERS: Must be OEM complete.
CAMSHAFT: Aftermarket cams allowed as per horsepower claimed. Must check on or under factory specs for lift, duration, and overlap.need to find out at what location they check the cam at and maximize the other areas. You might have done this already?
CYLINDER HEADS: All cylinder heads and valves and valve train must remain stock and unaltered as originally produced per year and horsepower claimed and also have correct casting number. Would have to talk to a pro but I bet there is some power here.
ENGINE: Must be same year and make for car used. Engine equipment, other than original, factory installed prohibited. Cylinder bores must not exceed .070 overstock. Bores are measured at the top of the cylinder where ring wear is not evident, Engine balancing permitted, however, excessive lightening of component parts is prohibited. Porting and/or polishing, any grinding in ports or combustion chambers, removal of any flashing, sandblasting or any other modification to cylinder heads and/or manifold or carburetors on cars in this section is prohibited. Stroke alteration is prohibited. Lots you can do here. Max bore, may be able to go farther if you nitride them.Lighten crank maybe a slight offset grind."prohibited" lol. Rod work to lighten and raise compression.I was talking to a well known racer and tuner about the cam setups once, asked about the stock lifters and he didn't say anything the first couple of times I asked, but there is some power there too.
EXHAUST SYSTEM: Stock OEM exhaust manifold mandatory with open exhaust. Headers permitted with OEM type mufflers, must be baffled and/or chambered. No straight through type allowed. Must be separate unit with outlet turned down or out to side of vehicle. custom headers, mufflers
FAN, GENERATOR, WATER PUMP: Must be connected and operable at all times. Belts must be tight enough to drive equipment in a satisfactory manner and without excessive or noticeable slippage. Must retain original factory produced fan. Stock size and material pulley must be retained. Water pump must remain stock. Electric fan may be added.
remove anything running on the belt you dont need.Dont know if all pulleys have to be stock size or not? put bigger ones were allowed.
PISTONS: Replacement piston must be stock as originally produced. Stock type and number must be used. Wrist pins, rods, and crankshaft must be factory original per horsepower claimed. Replacement piston may be forged or cast. Stock OEM dome must be retained.get them light, more compression, Coatings. Talk to machinists about best hone and rings.
POLLUTION CONTROLS: May be removed.pull it off
POWER STEERING: Power assist accessories and/or air condition pump drive belts may be disconnected during competition, provided they do not drive the fan and/or generator, or that removal of the power-steering belt would adversely affect the car steering. Power steering pump and air conditioning equipment may be removed. If you dont need it get rid of it. Lighter and more power to the wheels
SUSPENSION: Must be OEM per horsepower claimed. Any stock type shocks permitted. No other suspension changes or additions permitted.custom valved stock type shock. Drag race alignment.
TIRES: Any DOT tire permitted with full tread pattern. No recaps. Slicks may be 9 x 30 x 15 maximum sidewall designation. might go faster with different tires,maybe even smaller ones.
TRANSMISSIONS - AUTOMATIC: Must be stock OEM for horsepower and body style claimed. May not be altered except for addition of aftermarket shift kit. Aftermarket converters allowed.maximize converter for launch and top end.
UPHOLSTERY: Must have full factory upholstery, including factory carpet in place, No interior gutting permitted. It is required that the driver’s seat tracks be securely bolted down. If roll bar is installed, the rear seat may be modified to allow proper installation. Get rid of everything you can while keeping stock appearance
VALVE SPRINGS: Stock replacement per OEM spec. and must check on factory spec. open and closed pressure.Misht be able to shim them or other mods to increase pressure while they are on your heads if you need it
WEIGHT ADJUSTMENT: Same as Stock Eliminator. Lowest weight your allowed
WHEELS: Any type, as long as they are as strong as the original.Lowest weight possible
WINDSHIELD/WINDOWS: Windshield and all windows must be clear except for factory tinted safety glass and in good condition. Windows must be operative but closed during competition. Decals not permitted on any front door window or windshield, or rear window. z06 glass, lexan
Fuel, find the one that lets you make the most power by making timing adjustments.You might make more power if you raise the fuel pressure to get better atomization. I have heard the lt1 stock eliminator guys run 80-90psi fuel pressure. If you talk to someone who has been doing this awhile I'm sure they could tell you what works best. Sure I missed a bunch of things too. Stock racing still takes ingenuity, testing and lots of $$$$. Just have to maximize everything. If there is a better stock part that's legal run that. Lots of tolerance in the engine build, use the tolerance that will make the most power. These are just some of the things I would try but it might be cheaper, easier less wasted time if you talk/pay some of the pros.
Left out vacuum pump and reduce windage.
Another edit. The stock eliminator cars I have seen ran the 30x9 slicks. They make more power than you so they may not be the best tires for your setup.
If IHRA PS is like stock eliminator, it's a bracket race unless he comes up against another B/PS car in which case at heads up, he will win handily.
Scott, awesome 60ft times. 1.53 is good!
Ron
The exhaust system is 1 & 7/8" ARH off-road headers, X-pipe with no cats, and Ti exhaust.
Yes, Wendy loves racing and would be at the track every weekend if we could. Her daily driver is a 300C SRT8 and she simply loves cars. I catch her online in the evenings looking at early Corvettes.
She has only been to the track as a spectator with me and has never driven so we put her in the car Saturday. She loved it and did great! I went 11.74, 11.75 and 11.77. Her first pass (EVER) she went 14.50, then 13.05 and finally 11.98 and 11.91. That's a steep learning curve and she did wonderful. She is 140+ lbs. lighter than me (no comments please ...) and loves, LOVES being in the car so we are going to let her take over the driving duties and I'll do the maintenance. With her when she gets it figured out I know there is an 11.5x in it.
You've listed lots of "little" good ideas that will definitely add up and help. We're now to the racing and tweaking stage.
