Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Gear/converter question
Old Apr 3, 2014 | 03:03 AM
megac5's Avatar
megac5
Default Gear/converter question
Would 3.90 gears and a 4500 stall be overkill at the track?
Will i have Traction problems?
Can rear diff handle the hard launching?
I have a 98 c5 with a stock bottom end lq4 that ill be spraying a 200 shot to.... Mods now are 3.42 gears and 3600 stall with some 315/45/16 MT Drag radials..
With a 1.6 60'
Could I see some 1.3-1.4 60'? With the 3.90s and 4500 stall
Old Apr 3, 2014 | 03:19 PM
123sugey's Avatar
123sugey
Dig
You will see a 1.4X 60; with the 3:90's and 4500 stall with bolts ons if you have traction.
I would keep the 3:42's and add the higher stall
Old Apr 3, 2014 | 05:20 PM
megac5's Avatar
megac5
Why would you keep the 3.42s? I'd also like to pull the front tires just saying
Old Apr 3, 2014 | 07:14 PM
Rob Petyo's Avatar
Rob Petyo
I can cut 1.3's and still do not pull the wheels ... just saying
Old Apr 3, 2014 | 08:40 PM
megac5's Avatar
megac5
What stall and gear are you running if you don't mind me asking?
Old Apr 3, 2014 | 10:09 PM
Rob Petyo's Avatar
Rob Petyo
see my sig, there's even a video
Old Apr 7, 2014 | 08:28 AM
Tar Heel's Avatar
Tar Heel
We run a 3.90 gear, Yank SS4000 and 27" Hoosier drag radial. Best 60' has been 1.50 NA and we'll see about what a 150 shot does to it in a few weeks.
It's a little "loose" on the street but still driveable so if that is a consideration keep it in mind. We love our combination!
Scott
Old Apr 7, 2014 | 02:04 PM
blown81bu's Avatar
blown81bu
I think 3.90 be best for n/a...a 3.42 would b best for supercharged /nos application...run it hard ..dif should hold up as long as it dont wheel hop...
To Gear/converter question
