Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Help Slicks sizing!
Old May 8, 2014 | 09:39 PM
z0vette's Avatar
z0vette
Default Help Slicks sizing!
Guys,
Am using OEM F-body 16" wheels on my C5.
Am looking at MT's, Hoosiers or M&H slicks.
But need your recommendation for the right/correct size that will fit on these wheels.
Old May 9, 2014 | 11:56 AM
Tar Heel's Avatar
Tar Heel
Originally Posted by z0vette
Guys,
Do the 16" wheels fit over the rear brakes and spindles? I'm not familiar with these wheels but know when we put our 16" Bogarts on we have to get the LG drag spindles.
Assuming they'll fit (with some grinding on the ball joints) you may need to tell us a little more about your combination. Gear? Mods? If it's a stock Z06 with the 3.42 you'll find most guys like the 26" slick and make sure it's a bias ply because of the 6-speed. I personally like the 28" tire as IMHO it hooks better. You may have to remove the rear inner fender. Brand is up to you but I've always had good luck with Hoosiers. All will wear differently and require different amounts of burnout and heat to get them to hook.
Scott
Old May 9, 2014 | 02:33 PM
123sugey's Avatar
123sugey
Dig
Also besides tire height use the skinniest tire that will hold your power
Old May 10, 2014 | 12:40 AM
z0vette's Avatar
z0vette
True, I have gone through some grinding stuff to fit these wheels. And they do.
Now waiting to decide on the tire.
Scott
To Help Slicks sizing!
