Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
427 Bare Block Build
Old Jul 27, 2015 | 02:19 AM
Last C5's Avatar
Last C5
Default 427 Bare Block Build
LS7 bare block, Molnar Technologies crank and rods, Arias pistons, BT LS7 STG3 cam, AFR 235 VII heads, Dynamax headers, and Borla exhaust. 558 rwhp & 513 rwtq
Old Jul 27, 2015 | 07:26 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I'm sure you'll enjoy the power. What's the compression? Which BTR cam? Why the small heads?
Old Jul 28, 2015 | 12:12 AM
Last C5's Avatar
Last C5
Compression is 11.5 to 1.
BTR cam is the LS7 STG3 238/250 - 652/632 - 113.
Had the heads and Brian Tooley said put them on they won't hurt the overall result. Appears he was right as the motor put out more rwhp than a similar motor with larger heads.
I suppose I should start saving for a new differential now.
Old Aug 4, 2015 | 11:18 PM
~STOLEN~'s Avatar
~STOLEN~
Sounds awesome, have any audio clips, I'm debating on that cam
Old Aug 5, 2015 | 09:05 AM
Turbo-Geist's Avatar
Turbo-Geist
Looks like good results.
Was the similar motor tested on the same chassis dyno? Do you have any track results yet?
To 427 Bare Block Build
