Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Nitrous System Choices?
Old Sep 22, 2015 | 12:00 AM
RonSSNova's Avatar
RonSSNova
Default Nitrous System Choices?
Hey guys, not for my C5.
Really.
For a friends LS2 C6.
Really! :-)
He is looking to add up to 100hp.
Wet kit. And a way to effectively reduce the timing.
We really don't want to do a nitrous only timing table.
A4 car. I'll loan him my drag radials.
So looking for a nice quality kit.
Ron
Old Sep 23, 2015 | 12:06 AM
CactusCat's Avatar
CactusCat
Hey Ron, how's it hangin' ? To be honest with ya, only two outfits come to mind on your question. Nitrous Outlet and Nitrous Express. I believe both are forum vendors. A call to either one or visiting their websites should get you pointed in the right direction.
Old Sep 23, 2015 | 02:51 PM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
Good talking to you Ron.
I'll be awaiting your friends call.
Old Sep 23, 2015 | 03:17 PM
Tar Heel's Avatar
Tar Heel
Both great places Ron and you can't go wrong with either. We just happen to run Nitrous Outlet but that was simply because I found a killer deal on a COMPLETE (every possible bell and whistle including a NANO system) BNIB kit and I couldn't pass up the price. I'm happy with our kit and have been VERY happy with the technical support from Nitrous Outlet but I've also read great posts and responses from Nitrous Express and they are also extremely knowledgeable and professional. Throw a coin in the air and pick!
Scott
Old Sep 23, 2015 | 09:08 PM
mcshocks's Avatar
mcshocks
Talk to the guys over at Nitrous Outlet, as far as controlling timing look into the Lingenfelter LNC controller specific to his model car. The LNC gives control of timing and also a 2 step function.
Old Sep 24, 2015 | 09:05 AM
Tar Heel's Avatar
Tar Heel
Good point. We use one of these.
And by the way Ron, it's ok to admit that you're coming over the "dark side" instead of pretending that it's for a "friend".
Scott
Old Sep 24, 2015 | 10:14 AM
RonSSNova's Avatar
RonSSNova
Hey guys,
I'm doing well, thanks. I drive the vette daily! But am racing the Nova. Being nice and not beating on the C5. :-)
The nitrous really is for a friend. Actually for his girl friends C6.
I passed on Billy's contact info.
Seems like it would be pretty easy to rig up a switch and resistor affair to trick the IAT input to pull timing on the bottle when at WOT. But the consensus is that it's not needed.
Ron
Old Jan 16, 2016 | 09:33 PM
SPEED750's Avatar
SPEED750
With a wet kit 100 shot I wouldn't worry about pulling timing. You're only adding 12.ish HP per cylinder. I would get the plugs spec'd for nos for sure. I ran a 125 wet shot on my c4 without pulling any timing with no problems. You just have to be smart, don't hit it below 3000 rpm and always use the best gas you find. If your local gas is crap , just get some decent octane booster. A quick search will tell you which plugs are best for nos.
Old Jan 18, 2016 | 08:06 PM
dankhts's Avatar
dankhts
I've been running N/A for years, decided to try nitrous for a while.... Called about every vendor and they're all good, went with Nitrous Express they gave me the most time and answers plus a Corvette Forum discount for the best price..
Old Jan 25, 2016 | 08:19 PM
dennis50nj's Avatar
dennis50nj
I run there full kit, i did nozzle and stand alone, run c16 in it, have all bolt/ons and H&C run 10.1s NA on 93 pump and with a 100 shot no KR threw the entire pass, got there pressure heater.
Old Jan 28, 2016 | 04:41 PM
Anthraxmm's Avatar
Anthraxmm
That might be ok if the car is running a stock tune, but if it has already been tuned it likely has some advance in it and would definitely need to be pulled even on a 100 at least 2* I would do 4* (2*/50hp). Especially if pulling fuel off the rail. A $200 lingenfelter lnc-2000 is to easy to use for peace of mind. And a lot cheaper than fixing a piston with a hole in it, or with no more ringlands lol. I'd run some non projected spark plugs like a ngk br7
To Nitrous System Choices?
