Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
lost my first race
Old Nov 24, 2015 | 04:00 PM
romandian's Avatar
romandian
Default lost my first race
well, kind of race and kind of lost. my 99 c5 (automatic) has a centri blower and is otherwise stock. i cought up with a bmw m5 and the guy started pulling at about 60 kmh. i was in second gear and he got away until i came into the powerband. then i was able to keep up. i shifted into third and went of the throttle at about 140 kmh (speed limit is 80), but he stayed on it and disappeared.
im surprised that thing is so fast. it must have been the new biturbo, rated at 560 hp and 760 nm. im seeing 0.6 bars at 5500 and 0.8 at 6400, so i figure i have the same power, but the bmw is half a ton heavier.
this made me wonder about our gear ratios. why do we need a 3:1 first gear? that takes you to 3200 when shifting at 6000. 2.5:1 would make more sence.
Old Nov 26, 2015 | 07:14 AM
corvet786c's Avatar
corvet786c
Maybe it would be a different story if it was a manual car.
A4 which is what I have are more consistant in a straight line race. You might have gotten him in a straight line race, A lot of factors to consider. Don't feel bad.
Old Nov 26, 2015 | 07:23 AM
WICKEDFRC's Avatar
WICKEDFRC
I had my 2000 FRC with me out in Germany (2006) and caught up with a BMW M5 as well. We were both game, and it was on!
It was a very fun cat/mouse chase from Frankfurt all the way back to Wurzburg. And neither of us could gain any true distance due to road traffic and playing safe. However, once we got into the outskirts of Wurzburg, the Autobahn opened up to 3 or 4 lanes and we both mashed it.
At that time, I had a forged 402, heads, cam, intake, longtube headers, exhaust, tuned etc and put down 505 tq and 495 HP.
I barely pulled him at top speed, BUT I PULLED HIM.
We were over 190 mph when I began to pull him. Other than that, it was dead even all the way up to 191 mph when I backed off and he blew passed waving and smiling while his wife was reading the Deutsche Gazette and shaking her head. Hahahahah
Ya win some, ya lose some. I lost horribly to a 996TT with "upgraded turbos" that pulled me so hard, I watched his taillights disappear on Autobahn 5, outside Frankfurt. When we returned to our link-up side, only then did he tell me he had his turbos upgraded and reached 204 mph!!
Have fun. Be safe.
Also check out RACE WARS in Eisenach, Germany. Alot of fun!!
Old Nov 26, 2015 | 08:55 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
A blower car will need about 100 hp more than a N/A car to beat it because of the way blower consume power and make peak boost, until the compressor is at full speed, you aren't at full boost or power and a N/A car will leave you.
My guess is that a turbo car would run similarly, no parasitic loss from the blower and full boost much quicker. So you may make the same or similar power, the other guy may have made max power well before you did (area under the curve) and that's why he beat you with a heavier car and similar power.
Old Nov 26, 2015 | 02:03 PM
romandian's Avatar
romandian
http://www.bmw.ch/dam/brandBM/common...3899041491.jpg
0-100kmh time is advertised at 4.3 sec. weight 1950 kg. he only gets full power at 6000 rpm.
well anyway, its a nice car and surprisingly not so expensive at around $110 000. he had no problems putting the power to the ground. apparently he gets full boost at 1500 rpm.
Old Nov 26, 2015 | 03:05 PM
Millenium Z06
Moderator
Full boost at 1500 is the thing, you probably aren't getting full boost until above 4500
Old Nov 27, 2015 | 01:31 PM
romandian's Avatar
romandian
i dont really agree, its more a matter of gearing probably. he has a 7 speed auto i understand. if i had a taller first i could have used it and he woul not have been able to get away at 60 kmh. on the other hand im sure i cant put more than about 15%+ power to the ground being in second so im intrigued how it works on the m5 sedan. the weight distibution must be less favourable, but maybe not?
i find this interesting. how can boost be all in from 1500 to almost 6000? a sequential set up probably. however i have done a sequential engine before and boost was all in 2400, redline being 6700. so i dont know.
btw, im getting full bost at the rpm i choose to shift at.
quick calculation: his 4.3 sec. c5 is (from memory, auto) 4.9. o.k. thats 0-60 mph. 96.5 kmh. we need another 3.6%. so even assuming acceleration is 30% lower it works out to 4.9 + 4.9 X 0.036 X 1.3 = 5.1 sec. if i had 50% more power (i must have more) in the relevant rpm band that should convert to 5.1/1.5 = 3.4 sec. remember, my boost goes up to 0.8 bars.
anyways, i learned im not king of the road, not yet, but i can still remove the restrictor and get up to 1 bar boost.
Old Nov 27, 2015 | 07:38 PM
Millenium Z06
Moderator
Look at a TT M5 power curve vs yours, any car that's making significant torque much earlier than you with simialr HP levels is going to walk away from you because of where the power is built.
A car with a peaky power band vs a car making the same or slightly less power but with a relatively flat power band is going to beat you because he's in power longer than you are.
To put it simply if I make 400lbft of tq at 2500 and peak at 5250 with 510 vs you making 550 tq at 5250 but not cresting 400 till 4500 rpm, I'm down the street while you're waiting on power.
Whether or not you agree is immaterial because the M5 with a flat tq curve just proved it.
Even if he didn't have full boost until 2400, you don't until around 4500-5000, you;re boost is dependent upon belt speed and the supercharger eats up some of your power.
Old Nov 28, 2015 | 09:54 AM
95rtturbo's Avatar
95rtturbo
I'm going to say it's a combination of tq curve, and gearing - with both going tremendously to the M5s advantage. Both of you guys are correct. That is my politically correct answer.
Old Nov 28, 2015 | 01:09 PM
romandian's Avatar
romandian
lol. if m5 shifts at 7500, where do the seven gears take him? no idea, to 5200 perhaps? the torque below that is nice, but doesnt matter for all out acceleration. i hope this is also politically correct. lol.
still a mystery to me, how he can hook up the power in a lower gear than my second. he has 295 street tires. i cant hook in first on r888s.
Old Nov 28, 2015 | 01:30 PM
95rtturbo's Avatar
95rtturbo
The benefit of having 7 gears instead of 4, is that the gears are more closely spaced, resulting in being in a more optimal RPM most of the time. Not to mention the tranny in the M5 is more advanced than the stock C5 auto tranny - shifts are much quicker.
Old Nov 28, 2015 | 02:18 PM
Millenium Z06
Moderator
Yep, much like the M6 vs the M12 trans
Old Nov 28, 2015 | 02:23 PM
Millenium Z06
Moderator
It does matter, torque is what accelerates a car, not horsepower.
If he has 400+ lb ft from 2000 rpm thru 6000 vs you having 250-300 below 4000 and cresting 400 around 4000 and peaking at 5250, you have far less overall torque.
Why do you think the fastest cars at 1/4, 1/2 and mile events are always TT cars? They build more torque across the powerband vs a peaky curve. HP is a selling point, thats why you here about it more, torque is far more beneficial but not nearly as "sexy" as HP.
If you make big TQ, you'll always make big HP, the inverse isnt always true
Old Dec 4, 2015 | 03:54 PM
Milan's Avatar
Milan
You obviously don't live in a place where people race diesels. If you take two identical cars, the one with more horsepower will always win. Horsepower is the work being done...a body builder is stronger than Lance Armstrong, but is he going to beat him in bike race? No.
That BMW was probably modded making way more power than you.
To lost my first race
