Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Time to guess Dyno numbers again!
Old Mar 5, 2016 | 10:02 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Default Time to guess Dyno numbers again!
My car put down 557 rwhp early last year when I was running the older procharger twin intercooler setup with a 4.0 pulley. I was running 6lbs of boost then. I have since changed to the latest A&A front mount ram air intercooler, swapped to a 3.7 pulley and added methanol. What would be your guesses on my power level now. Probably will dyno in about a month.
Old Mar 11, 2016 | 10:42 PM
95wht6spd's Avatar
95wht6spd
Stock LS1 except cam?
Meth tune for safety or power?
I thought you were selling SC?
I will be interested in results, as I have the twins too. Are you doing work yourself?
Old Mar 11, 2016 | 10:57 PM
NVTHIS's Avatar
NVTHIS
Decided on keeping the supercharger, since I decided to add meth. It's a stock Ls6 with the big blower cam and supporting components and kooks longtubes. Everything on this car is from the torch red 2001 z06 I previously had (long story). Meth will be tuned for more safety, I think, lol. I like the simplicity of this new front mount intercooler. With the tigershark fascia this new front mount intercooler should really get the air it needs. I have done all the work except the tuning, and a good friend of mine does it.
Old Mar 12, 2016 | 12:14 PM
95wht6spd's Avatar
95wht6spd
So hard to say on FI, but I guess around 620. I think most of the gain will be from smaller pulley and retune w meth, as I don't think the twins were much of a restriction yet. I think you will get even more real world results at highway speed with the ram air effect.
Was the change difficult to do, did you already have cradle modified?
Let us know if you see any rise in temp after the tune and it gets hot out, since the rad will now be covered with the IC.
Old Mar 12, 2016 | 11:14 PM
NVTHIS's Avatar
NVTHIS
Those numbers were kinda in the range i was thinking. The change from twins to single was very easy to do. I don't know if the twins had any restriction as opposed to the front mount, but the piping and all was so much easier to route than with the twins and you can easily inspect the front mount. I have the cradle dropped on A&A spacers. That's the only modification done on it. I'm running a 2" cut down DeWitts radiator with spal fans. Hopefully that will help with the temp. I'll let you know how it does.
Old Apr 10, 2016 | 01:55 AM
NVTHIS's Avatar
NVTHIS
Will be going to the dyno on Saturday 4/16. Will update then with the results.
Old Apr 19, 2016 | 05:21 PM
NVTHIS's Avatar
NVTHIS
Results are in! It would have made more, but was running out of pump, so had to stop. Time to upgrade to twins! It made 646 rwhp and 500 rwtq.
To Time to guess Dyno numbers again!
