It wasn't fair as my car is built w Nitrous... But the guy had been running his hole.... His was a gorgeous car!!! Love the white C7Z w the red interior...
Does sound like a cool combo. Regardless of the means, you represented the C5 community well. Nice job brother.
Or perhaps mine is just that much faster.... Thanks my friend... Also have a vid against a new 5.0 running a Turbo making 800ish... Gorgeous car though, Running dark Stars, skinnies up front... I even gave him a head start.
1000 rw C6Z was also a great run.. Although his trap speed was faster than mine I still beat him to the flags. Keep in mind my go Pro was on the back of my car. This was my first time using it so I didn't know how to turn it off at first...lol... My car makes some hella TQ... It goes back under the knife in July...
I know..., I couldn't resist.
Perhaps milling the heads, ( bump compression), port match to my 102, Direct port system, change up valve train geometry, different push rods, a trick or two to the bottom end... GZ vacuum pump.... That will just about do it....
Finished this today....
my comment was a joke obviously... what are you going to do now?
Dont put anymore money in those heads, if you are going to spend money on heads, move to some TFS or LS7
