Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
C5 auto tranny problem
Old Oct 5, 2016 | 09:59 PM
nr4m's Avatar
nr4m
2nd Gear
Default C5 auto tranny problem
Hello all,
New to the list, as I'm trying to track down an issue that I'm totally unfamiliar with.
I have a 2002 Lingenfleter twin turbo convertible that I 'sorta broke'.
I was giving a friend a ride on a country road and put my foot in it from about a 20 mph roll. Half way thru 2nd gear and pulling really hard, 'bam' the engine free wheeled and immediately bounced off the rev limiter.
Long story short... after I stopped and checked my underwear, the car would not move. It was as if it was in neutral. I put it into 1st and it went just fine, then shifted to 2nd and then drive, all with no issue. Ran fine except anytime my speed dropped below 20 mph, it free wheeled as if it were in neutral. I had to manually run thru the gears again.
Manuals I'm OK with, but not automatics. This tranny was done about 8 years ago by someone who does it professionally and he did a great job. Problem is he's hours away and would be a pain in the butt to get it to his shop.
Someone recently mentioned that it may be something as simple as a 'sensor' or some such thing.
Those of you who know these trannys, do you have a suggestion? Do you recognize the symptoms?
Any help appreciated. ( I do have a lift...)
BTW, this is a twin turbo, 725 hp with way wide tires. 345r-30 19's. Very streetable till you put your foot into it.
http://www.zeroto60times.com/fastest...-60-mph-times/ Number 4 on the list.
Old Oct 5, 2016 | 11:07 PM
junk c5's Avatar
junk c5
I assume the car is greatly detuned if it makes 725 currently. Where are you located. There's a couple trans shops that build killer 4l60e's and I'm certain they could point you in the right direction. Chances are real good the trans is going to need to come out. Fortunately you have a lift, I took mine out 1/2 a dozen times on the ground.
Old Oct 6, 2016 | 11:04 AM
nr4m's Avatar
nr4m
2nd Gear
Thanks for the reply.
I'm in central VA and the shop I used is in N. VA. Not that far mileage wise, but no fun pulling a 24 foot enclosed trailer thru N. VA traffic.
The fellow I used is Wayne Rogers from Rogers Automotive in Chantilly, VA He's a Pro Mod driver, so I feel he knows the performance end of things.
To C5 auto tranny problem
