Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
E85
Old Apr 21, 2017 | 01:42 PM
MMA FIGHTER2's Avatar
MMA FIGHTER2
Default E85
Has anyone switched there c5 over to straight e85, if so what did you have to change over?
Old Apr 21, 2017 | 08:39 PM
Drewstein's Avatar
Drewstein
Entire fuel system from pumps to lines to injectors.
What mods have you done to warrant the switch?
Old Apr 22, 2017 | 07:30 AM
MMA FIGHTER2
I have a iron block 408 heads ,can, fast intake, all the goodies. And I'm adding a super charger down the road.
Old Apr 22, 2017 | 07:11 PM
junk c5's Avatar
junk c5
Injectors, Fuel pumps, boost reference fuel pressure regulator, rails, -10 supply & return lines and I pulled -8 wire to some fuel pump relays.
Old Apr 24, 2017 | 06:26 PM
Drewstein's Avatar
Drewstein
Well if you do it early you'll probably be buying two sets of injectors which is extra expense as NA E85 and boosted is drastically different.
As we posted, it's the entire system when you decide to switch.
Old Jun 30, 2017 | 03:30 AM
Podium's Avatar
Podium
E85 is thirsty but you do not need to replace the entire system. The OP is going to need a big fuel system when he supercharges that 408 regardless of fuel.
Old Jun 30, 2017 | 08:03 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
^^this.
OEM fuel lines and regulator. Walbro 255 with a BAP and Hotwire kit.
85lb injectors.
14.5:1 427 on E85.
72% IDC
Ran mid 9s at 142mph at 3050 race weight.
Old Jun 30, 2017 | 05:41 PM
Podium's Avatar
Podium
Originally Posted by Capthuff
^^this.
85lb injectors.
14.5:1 427 on E85.
72% IDC
Yep. Lots of E85 myths out there.
Old Jul 3, 2017 | 11:33 AM
neoVVL's Avatar
neoVVL
Exactly. No need to change anything but the pump and injectors. How much power are you looking to make? I'm running a walbro 450 and a bap. Should be good for 750 whp ish I think..
Old Jul 3, 2017 | 03:54 PM
FourG63 97GST's Avatar
FourG63 97GST
injectors and tune is the minimum.
I run a secondary external fuel system. so my stock fuel system is running most of the time. which consist of stock pump, lines and fuel rail still.
upgrading the fuel system beyond that, comes down to how much fuel your setup needs
To E85
