BIG POWER e-85 808rwhp 650tq
4th Gear
Long time forum reader. And sharing with you guys what I did to my car. Picked up the car last weekend from SYNERGY MOTORSPORTS IN LIVERMORE CA couldn't be any happier with results, its got a&a t-trim 14-15psi, a&a stage 2 fuel system, 1000cc injectors fic=fuel injector connection, synergy motorsports custom cam, high flow oil pump, ported and milled heads-.20, long tube headers no cats, rpm stage 5 trans, 390 gears with c6 zo6 output shafts, Mcleod RXT w/steel fly, and yes still stock bottom end--
great numbers, esp on a stock bottom end my brother is having a 76mm turbo built LS1 going into a 1991 RX7.. curious to see how his numbers match up to yours. he should be running close to the same boost. hes thinking 650-700 on pump gas. stock heads, turbo cam, valves, springs, etc are all done. stock crank and rods I believe.
