Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
power gains
Old May 19, 2017 | 08:50 AM
Randell Fuqua's Avatar
Randell Fuqua
6th Gear
Default power gains
hey guys I'm currently doing a build on my 98 vette Im putting an LG Executive cam kit, 92mm FAST intake, LS6 Heads, long tube 1 7/8 headers, C5 Z06 H pipe, with magnaflow cat back exhaust. I was wondering what kind of power gains I could or should see out of this set up.
thanks
Randell Fuqua
Old May 19, 2017 | 09:00 AM
99blkfrc99's Avatar
99blkfrc99
thanks
Randell Fuqua
97.34whp after tune
Old May 19, 2017 | 09:21 AM
Randell Fuqua
6th Gear
Originally Posted by 99blkfrc99
97.34whp after tune
What do I need to do to get at least 400 rwhp
Old May 19, 2017 | 10:12 AM
99blkfrc99's Avatar
99blkfrc99
Really depends on the dyno. If it's a dyno jet you will be there, if it's a mustang or dyno dynamics you should be close.
Old May 19, 2017 | 10:42 AM
NosLaser's Avatar
NosLaser
I would ditch the factory H pipe and go with a complementing X pipe that goes with your long tubes.
What are the specs on the LG Exec cam?
Old May 21, 2017 | 09:55 PM
RockyMtC5's Avatar
RockyMtC5
You should easily get over 400 RWHP. My guess is 420rwhp/385 ft lbs after dyno tune
Old May 30, 2017 | 06:25 PM
Scotty2000SS's Avatar
Scotty2000SS
This...
You'll pick up a good amount not to mention it will sound so much better.
To power gains
