Torquer V2 232/234 .600"/.600" cam on stock ls1?
Is risking your entire motor worth saving an hour of your time and $200?
Don't do any cam without upgrading valve springs
A google search or forum search would answer this with thousands of responses telling you hell no
/endthread
/endthread
Nope. You need to replace the springs to ones that are rated to at least 0.600 lift. Factory springs are only good to 0.570.
Also, you will need a tune with that big of a cam. And if you have an auto trans, you would probably also need a higher stall torque converter.
Asking questions about a cam for your car is not a simple question. You need to define your goals and how much money you want to spend.
For a stock car with stock springs, I would recommend this cam: http://www.cammotion.com/camshafts/l...-218-224-16-3/. Even then, I would recommend a fresh set of factory LS6 springs.
