Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
02 Dyno with Callaway honker
Old 03-23-2019, 03:59 PM
WAz06
WAz06's Avatar
Default 02 Dyno with Callaway honker
02 z06, Car has 13,000 miles and Callaway honker intake. Only other mods are Forgestar f14's 18/19.
Should I be concerned why my torque is so low? Not sure if it's just how the dyno was set up because the HP curve looks a little weird mostly running at a 45 degree angle.
Old 03-25-2019, 01:13 AM
itsonlyairandfuel
itsonlyairandfuel's Avatar
Ok, I will bite. 129 views and no comments? That chart does not look anywhere normal. Hope it runs okay.
Old 03-25-2019, 10:13 AM
WAz06
WAz06's Avatar
That's the thing as far as I can tell there's no indication it's not running well.
Old 03-25-2019, 10:19 AM
Kingtal0n
Kingtal0n's Avatar
I think that engine is only 5.7L , in 2002
They are 380-405bhp
So 350~ rwhp is about right
The dyno works by calculating horsepower first, then, if you happened to connect the ignition clamp, it will work backwards to get torque.
The fact you have smoothing=0, and the line is very smooth, is a very good sign.
The engine making incredible VE at 2200rpm and carrying it to 6k is also amazing
Next time get an A/F curve but overall it looks good to me
To 02 Dyno with Callaway honker
Quick Reply: 02 Dyno with Callaway honker
