Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Launch Tips Base C5 Auto No Mods
Old Jun 16, 2020 | 10:48 PM
Equator's Avatar
Equator
Default Launch Tips Base C5 Auto No Mods
Somewhat embarrassed to ask this question, based on the incredible cars and the setups I've seen here. I have a 2002 base convertible with an auto transmission, 3.15 rear, and 40,000 miles. Semi daily driver. Very simple and plain for now.
What is the best way to launch this from a stop? I have read to turn off traction control, but from there, opinions vary. Use the brake and rev to about 1300-1500 rpms? Just mash the accelerator from the start and go? Lower the rear tire pressure to 25 psi? A lot of the performance tips I have seen are for manuals, or cars with a lot more upgrades than mine. I know I won't be winning any titles with my current setup, but want to put in a decent showing for myself if called out by something I might be able to beat.
I plan to up the performance a little more with long tube headers, a cai, stall converter, and a tune later this summer. From there, maybe a supercharger. But for now it is what it is, and I hope some of the tips will still apply after some upgrades. Thank you in advance for any advice.
Old Jun 19, 2020 | 11:12 AM
JayhawkCPA's Avatar
JayhawkCPA
in the auto's i've had, idle up to the stock stall with about 1/4 throttle, when you leave punch it 1/2-3/4 throttle, if it hooks go full throttle, you should hook up pretty good in stock form...unless your tires are bad...if it dead hooks just mash it! :-)
