Katech Stage 2 C5 Z06
I’m looking at purchasing the Katech stage 2 kit and was curious if anyone here had bought it yet. I was also mainly curious about the cam (Katech-7293) and what type of performance it had and numbers it made.
But that being said... is it the $7488 kit listed here?: https://katechengines.com/i-30497597...6-stage-2.html
Because all that is is a Heads/Cam kit for 3.5 times the price.
What is your GOAL for the car? Sound mean? Drag strip ripper? Beat the local dudes? 1/2 mile runs? Just want to have XXX power? XX.XX quarter mile time?
Because you can get an entire brand new supercharger kit, INSTALLED, and have a spare $1,489 left in your pocket while making 550hp TO THE WHEELS, not just at the crank like that Katech combo and have the car still drive and handle like stock.
OR you can buy a nice set of heads, choose a cam to fit your goals and make that same 550 crank hp for about $2500 give or take. It can be done cheaper if you have a set of 243 heads to send out to be CNC milled.
Options abound. Let the group know what your goal is and there are guys with a lot better cam knowledge than myself who can chime in and point you in the right direction.
Sounds like you're moving in the right direction though. The car will be fun!
So it’s a track build, time attack and HPDE. I have an unknown GM hot cam, I believe modified by Howard’s that is worn out. I already have ported heads, I’m more interested in a cam. I was curious if anyone has that cam or similar specs and what number they made.
I can include additional info on the car if needed.
I don’t want to go supercharge route, since I’ve heard things about the car running hot with them. Especially on the track with 20 mins sessions or abuse. The car already runs hot stock with no modifications.
I’m looking to get into the 550hp range.
A supercharger kit installed on a c5 z06 will drastically decrease handling performance for road course use and spirited driving. For a street / strip car, they can be a much better bang-for-buck though. You will make more power anywhere without a doubt.
I don't see how you can have $1500 in your pocket after purchasing a $6000 supercharger kit, that means labor and tuning is free. I guess you are assuming DIY'ers time is worth $0, and you would just use the provided basic tune.
Don't worry, I do push the Katech remote bleeder on as many people as possible. It makes sense to have the same adapter style as factory vs the popular crush washer. I have one of each and have had no issues with either one. You guys just make the better product for those.
Zach,
I’m curious on the HP gains from the cam. I see there is a targets HP number of 550. Is that to the wheels or crank? I also am interested in the numbers of the cam; 219 / 227 @ 0.050, 0.607/0.614 lift, 112 LSA. I saw that other other cams have a higher duration and lift. A higher duration would some what increase the HP, correct?
I have LT headers, ported heads, and will be getting the FAST 92mm intake and TB.
Any experience with a C5 with similar mods and what type of numbers it made?
No way 550 is rwhp.
But to each their own. Maybe spend more time talking and going back and forth with some guys or hit a few events FIRST to see what you like. Because it sounds as though you have a goal you wish to reach - and there are a thousand ways to get there - but that you don't have a firm grasp of cam design or how it will affect car performance in the way you're going to use the car. Events first. Build later.
Our background is from award-winning road racing on a professional level. Our primary goal in HPDE packages is retaining area under the curve. Extreme lift does not determine valvetrain wear, we have run as high as .725 lift with hydraulic roller (and the appropriately modified valvetrain geometry, with a stock 1.8 rocker arm) with near 0 wear. There are a lot of factors that come into play when you consider your engine's valvetrain, this is why we validate any package we sell on our spintron in-house, with a safety factor of 1000 RPM. If you just slap in a generic cam that has high lift without the supporting items, you likely will get expedited wear. This isn't the lift's fault, it is the entire system overall.
