Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Has any one used a fluid dampner
Old Jun 15, 2004 | 03:46 PM
hydfixer1's Avatar
hydfixer1
Default Has any one used a fluid dampner
I was woundering if they are any good. And when you use one do you have to do any balancing to the front or the rear of the crank?
Old Jun 15, 2004 | 04:46 PM
wrustywrench's Avatar
wrustywrench
Default Re: Has any one used a fluid dampner (hydfixer1)
forget fluid and get an ATI,,,,well worth it, just install and go , no extra work needed with either,,,
[Modified by wrustywrench, 9:47 PM 6/15/2004]
Old Jun 19, 2004 | 10:11 PM
crainholio's Avatar
crainholio
Another vote for ATI here, mine's been great thus far both on the street and track. Engine winds up smooth as silk.
ATI balancers are what's used on the spec LS1 crate engines used by the ASA, good enough of a reference for me.
I also liked that they only underdrive the accessories by 10%, rather than 25% like the majority of the aftermarket pieces. -10% is enough for me.
Old Jun 20, 2004 | 11:56 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Default Re: Has any one used a fluid dampner (crainholio)
how much for ATI and how long of a job to install in C5????
Old Jun 21, 2004 | 06:16 PM
crainholio's Avatar
crainholio
Default Re: Has any one used a fluid dampner (DragMan)
Check Thunder Racing for prices -------------------------------->
You'll want a new crank bolt also.
As for how long, depends on how much trouble you have w/ tools. It took me ~45min, the majority of which was removing the old balancer.
I had access to the J-tool for installing the balancer which helped considerably. Big threaded rod, roller thrust bearing, and nut. Just slide the balancer onto the crank snout, install the tool, and pull the balancer into place using the nut and thrust bearing.
Old Jun 21, 2004 | 06:20 PM
DragMan's Avatar
DragMan
did u have to remove rack to install balancer????
Old Jul 1, 2004 | 08:09 PM
juiced's Avatar
juiced
yes you have to pull the rack... thats not the worst of it if you have a power steering cooler thats the real pain. it doesn't come out easily, easy to bend/break lines
To Has any one used a fluid dampner
