Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Help...Gears or Headers for lower ET's
Old Jun 26, 2004 | 10:27 PM
CYA-Vett's Avatar
CYA-Vett
Default Help...Gears or Headers for lower ET's
I want lower ET's I could care less about HP, plus I want to build a sleeper.
Heads and cam may be in the future but I was wondering which would knock more off of my ET gears or headers.
Also recomendations on either would be appreciated.
Thanks,
Dave
Old Jun 27, 2004 | 11:29 AM
mdhmi's Avatar
mdhmi
Default Re: Help...Gears or Headers for lower ET's (CYA-Vett)
Considering you have an 03 Z06 my advise would be to skip the H/C for now and get LT headers and an air intake. Next invest in a line lock, better tires, and a hardened rear diff. I think you'll be pleasantly surprised..
Cheers,
Mark
Old Jun 27, 2004 | 12:28 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Gears for sure. 3:73s should be worth 2/10 and 3:90s another 1/10 assuming that you have traction. Cartek is not that far from you, give them a call.
Old Jun 27, 2004 | 06:55 PM
robz's Avatar
robz
Default Re: Help...Gears or Headers for lower ET's (JerryL)
i started out doing 3.90's and headers together. They work well together but you need at least drag radials at the track otherwise you may run slower do to wheelspin. I would do headers first if I had only one choice. Then its all about seat time before you go too mod crazy!
Old Jun 27, 2004 | 07:09 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Thanks,
Dave
What about tires?
Old Jun 27, 2004 | 07:42 PM
CYA-Vett's Avatar
CYA-Vett
Default Re: Help...Gears or Headers for lower ET's (EB20003)
I do currently run the G-Force Drag radials, I have the Vararam and Stingers.
I run 12.4's
I want to go quicker, safely. Warranty.
Yes, I do need more seat time too, I'm impatient!
I also figure I can slip gears past the dealer if something happens to the motor, headers I would hope are fine. Once I go to cam and/or heads, I'm screwed.
Old Jun 27, 2004 | 09:59 PM
mdhmi's Avatar
mdhmi
I would stay away from H/C if you want to keep your warranty. LT Headers + a 100 shot of N20 and your car would absolutely scream.
Mark
Old Jun 27, 2004 | 10:38 PM
LeMansBlue04's Avatar
LeMansBlue04
Default Re: Help...Gears or Headers for lower ET's (mdhmi)
IMO... Do not waste your money on 3.90 gears, go lower. You would be better served by 4.10s, remember that you have 2 overdrive gears in your manual trans. Tires with a good grip and lower gears are more likely to improve your ET than headers alone will.
Old Jun 28, 2004 | 02:58 PM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Help...Gears or Headers for lower ET's (LeMansBlue04)
Gears will get you more than headers, IMO.
Old Jun 28, 2004 | 03:50 PM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Help...Gears or Headers for lower ET's (SleepieAce)
I'll be selling both soon as I'm going back to stock. Getrag 3.73 and TPIS LT headers w/offroad x-pipe. Also going to have a vararam for sale, let me know if you're interested.
Old Jun 28, 2004 | 05:14 PM
CYA-Vett's Avatar
CYA-Vett
Default Re: Help...Gears or Headers for lower ET's (NJVetteGuy)
How old is the stuff (Condition)....probably interested. I plan on getting both eventually. Will the factory cats/x-pipe bolt on in place of the off road pipe for my emissions test? Already have the vararam...
Dave
Old Jun 28, 2004 | 06:23 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
They are more fun on the road but I didn't gain anything in the 1/4 mile. Same 60's and everything. Oh well, I guess they are worth it on the street but not on the track. Kaley
Old Jun 28, 2004 | 10:01 PM
jjk2509's Avatar
jjk2509
If CYA is not interested I am interested in the gears. Thinking about 342 or 373.
To Help...Gears or Headers for lower ET's
