Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
stock head modification
Old Jul 1, 2004 | 09:51 AM
98vert6spd's Avatar
98vert6spd
Default stock head modification
if i bought a set of stock ls1 heads and ported polished and milled 30 thousandths and put this on a nearly stock car what could i hope to gain?
are modified stock heads a bad idea?
would i be better off putting different valves springs and retainers?
Old Jul 2, 2004 | 12:22 AM
99 torch red vette's Avatar
99 torch red vette
Default Re: stock head modification (98vert6spd)
i am in the process in trying almost the same thing,
I have FLP full length headers, LS6 instake, UD pulley, vararam intake, I am adding the LS6 intake, MTI stage 2E heads with a 04 Z06 cam
I am hoping for 400 rwhp with a 6-spd.
I am wondering if anyone has done this b4?
Old Jul 2, 2004 | 10:26 AM
dahoof's Avatar
dahoof
I am guessing between 20 and 30rwhp. You will not gain power with springs and retainers, just a stronger valvetrain setup.
Old Jul 2, 2004 | 10:29 AM
98vert6spd's Avatar
98vert6spd
Default Re: stock head modification (dahoof)
if i were to have a set of stock heads of the car and time was no option because i had a set of heads still in the car what would you do with the heads to get the biggest bang for your buck?
mill?
different valves?
port polish?
Old Jul 2, 2004 | 03:40 PM
dahoof's Avatar
dahoof
To get the most power from the heads you would have to do all of the above plus a port and polish.
Old Jul 3, 2004 | 03:46 PM
mercxrr2's Avatar
mercxrr2
It depends, on how much over stock the heads flow and the ability of the exhaust to handle the increase gas's flow.
Assuming that there were no intake flow limits. Maybe 20 HP, if the head flowed as will as a LS6 and 5 to 10hp for the increase in compression
Old Jul 5, 2004 | 09:36 AM
ROD BROWN's Avatar
ROD BROWN
I am not sure,but someone in the know may be able to contribute to this thread.I believe if you mill the heads,you have to remove an equal amount from the intake manifold.I read this article in Hot Rod Magazine a while back,but I don't know if it is the Gospel.I would look into that as it could cause problems down the line when the car doesn't run right due to manifold leaks. :flag
Old Jul 5, 2004 | 08:56 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Default Re: stock head modification (ROD BROWN)
To stock head modification
