Mustang dyno has a whole diff set of numbers--I think on a dynojet you would be noticably higher--the 390s will read about 15 rwhp lower---I would skip the weiland it will rob 10 to 30rwhp from your motor it is a heatsink--you can polish them and make them pretty but they rob power so if you are looking for an increase in power this intake will take back everything else you have done to the car--get an ls6 intake or go ahead with a 90mm FAST setup when you are ready to do the heads and cam.
I'd say 5-10.. The Z06 airlid and K&N will be the limiting factors. Though better than stock, still leaves a lot to be desired vs a good aftermarket intake system IMO. I ran the Z06 airlid and K&N, along with my Corsas, then went to a Blackwing and picked up about 18 horses after doing so.
My A4 dynoed out at 300 RWHP with the Blackwing and Corsas, when I had 2.73s. And about 281 and some change with the Z06 airlid/K&N setup..
