Does anyone know the difference between the gross and net methods of HP measurement? Sometime in the early 1970s, the manufacturers switched from gross HP to SAE net HP. There seems to be about a 20 - 25% difference. It is sometimes deceptive to compare HP ratings from cars in the 1960s to HP ratings of modern cars because of this measurement difference.
Yeah.. I believe it was back in '72 when they changed from the gross hp rating to the net hp rating. What they used to do was dyno the engine without any accessories. In '72, they started dyno'ing the engine with the accessories that were going to be on the car including a full exhaust, all pumps, alternator, starter and any emissions controls. With this extra drag on the motor, the hp numbers were 20-25% less on average than without the accessories.
Just to let you know, they had a car tv show on recently that put a 426 Hemi Cuda 4 speed on a chassis dyno and the car only put out low 300 hp to the rear wheels. That's a far cry from the 400-500 gross hp rating at the crank that it had back in the hey day.
X
X
I also remember reading an article in a hot rod magazine in 1970. They put a 1970 SS454 Chevelle, which was the last year before the smog junk went into effect, on a chassis dynamometer and it only put out 220 HP at the rear wheels! It was rated as I recall as 450 gross crankshaft HP. After blueprinting and tuning the engine, I believe they finall got it up to something like 300 rear wheel HP. Still a far cry from the rated 450 gross crank HP. Since I grew up in the 60s, it is always good to get a sanity check to keep my memory from being distorted by my recollections of those muscle cars which I used to own. By today's measurments my Z06, at about 350 RWHP, puts out more rear wheel HP than that 426 hemi from the 60s. Old and new road tests also bear that out. It has taken over 30 years, but we are finally getting engines that surpass the power output of the best engines of the 1960s and we get a lot better gas mileage and reliability too.
Echoing and reinforcing a previous reply which became quite relevant to me in my search for a muscle car I could afford in the mid 80's. 1972 was indeed the year the "hammer" fell. Check most any muscle car's net bhp output and it will fall dramatically for 1972 and then slowly rebound impotently. I ended up buying an EXTREMELY used 1973 Mustang Mach 1 with the 351 Cleveland engine (and a disconnected nitrous adapter I didn't recognize at the time) knowing that it really put out "much more power" than rated. The books forgot to tell me that's maybe 300 "extremely unreliable, with a tailwind and 147 octane fuel dumped via external fueling jet due to rate of consumption" rwhp, which only manifests in a straight line on odd numbered days in months containing the letter J and when the side exhausts burped "Mine Eyes Have Seen the Glory" at random.
Bottom line: comparison of pre-'72 engine and post-'72 engine impossible via paper. Very possible via dyno, provided multiple runs are done. The Mustang, on the other hand, will have to be pushed across the laser beam just for an RT.
