Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Finally dyno'd the vette....
Old Aug 2, 2004 | 12:36 PM
SnowyATX's Avatar
SnowyATX
Default Finally dyno'd the vette....
All,
This morning I finally had the vette dyno'd. Sorry no baselines to compare to but my setup is as shown below. Note that this is SAE corrected and with NO tuning (yet). I was fairly pleased with the results considering no tune.
Factory PCM Tune
Kooks 1-3/4 LT's with cats
GHL Exhaust
MTI Stealth I Cam
LS6 Intake Manifold
ASP Underdrive Pulley
Donaldson Intake W/Cold Air Cover
TR55 Plugs
Taylor Thundervolt Wires
What do guys think? Any positive comments you may have are appreciated as I'm a still a Dyno newbie.
David at Maxwell here in Austin was great to work with and the pricing was great as well. I would suggest him to the Austin folks here on the forum.
Here is a bigger version
Last edited by SnowyATX; Aug 2, 2004 at 04:50 PM. Reason: Edited to include mods...i.e. my sig will change over time.
Old Aug 2, 2004 | 01:18 PM
SnowyATX's Avatar
SnowyATX
Does my A/F ratio show to be in a "safe" region or is it running a little lean?
Old Aug 2, 2004 | 02:44 PM
mdhmi's Avatar
mdhmi
Good numbers. You will likely pick up another 15-20 hp by having a full dyno tune.
Mark
Old Aug 2, 2004 | 03:02 PM
pwrshhftd's Avatar
pwrshhftd
AF looks pretty good to me...
i dont see a ton to be gained... usually you have a problem is its liek 10-11 range.
than there is power to be had from leaning it out a bit
Old Aug 2, 2004 | 03:16 PM
CYA-Vett's Avatar
CYA-Vett
I'm not too sure you'll pick up much peak HP, but your mid range numbers will definetly go up when you lean it out which helps alot at the track. Personally I'd rather have 10 across the board then 15 Peak and very little or none anywhere else.
Either way, those numbers are better than mine
Old Aug 2, 2004 | 03:20 PM
roscoe118's Avatar
roscoe118
Awesome numbers
Do you mind if I ask what they charged, and how long it took?
You can IM or email me.
roscoe
Old Aug 2, 2004 | 07:05 PM
don527's Avatar
don527
good numbers.
tuned i think 385-390 if maintaining a safe a/f
keep posting your findings.
Old Aug 2, 2004 | 07:17 PM
SnowyATX's Avatar
SnowyATX
Is it typical to have be leaner at lower RPM's like this graph shows? Am I too lean in the 0-4K RPM range? Want to make sure I'm running a reasonable conservative setup.
-Thanks
Old Aug 2, 2004 | 07:30 PM
STAGED's Avatar
STAGED
Old Aug 2, 2004 | 10:22 PM
Rays Vet's Avatar
Rays Vet
All,
Factory PCM Tune
GHL Exhaust
MTI Stealth I Cam
LS6 Intake Manifold
TR55 Plugs
Very good numbers!!! Around 1800rpms there is a small dip that might be indicative of a little lean and at 5500 up (the stagged lines ) is I believe the result of the springs.
Old Aug 2, 2004 | 10:31 PM
rollinred's Avatar
rollinred
with a good tune and ported heads you would be over 400rwhp and still have a smooth idle,that car is what you call a true sleeper,good job.
Old Aug 6, 2004 | 10:01 AM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
is it a M6 or A4?
See my sig for my A4 and i have almost the same mods. But my HP is around 25 less.
Old Aug 6, 2004 | 10:34 AM
SnowyATX's Avatar
SnowyATX
Originally Posted by spoiled996
is it a M6 or A4?
MN6
Old Aug 26, 2004 | 06:25 AM
Evolution's Avatar
Evolution
I would definately invest in a tune. It would be well worth it. Good numbers though.
Will
Old Dec 1, 2004 | 07:02 PM
SnowyATX's Avatar
SnowyATX
Installed some MTI 2E heads and had it dyno tuned today....see this thread: http://forums.corvetteforum.com/showthread.php?t=960075
To Finally dyno'd the vette....
